Using utility_meter to follow up home energy usage monthly. The utility_mete is collecting the energy usage in kWh from Aeotec HEM Zwave sensor. Yesterday, for whatever reason, the HEM sent some nonsense result for some seconds-minutes. So, the value of the utility meter changed accordingly:
At 10:00 AM, Home Energy Meter Energy sent the wrong values in spike, so the utility meter monthly_home_energy changed its value which increased from 1.131kWh in total to 56.294kWh almost instantly.
So my question is, is there a way to remove these wrong values either from the utility_meter or the sensor readings of HEM? I know that HEM values can be deleted from database but i am not sure if this will be reflected to utility_meter values?
