I am running the following:
Installation method: Home Assistant OS
Core 2026.3.1
Supervisor 2026.03.0
Operating System 17.1
Frontend 20260304.0
I have had a ReFoss energy monitor connected to my breaker box for a few weeks, but only to the main power (A1 and B1). On Saturday I connected a pair of the "individual: CT clamps (A2 and B2) to the breaker for my hot water tank. I then created a helper Template Sensor that combined the reported energy_this_month data from A2 and B2 into one sensor called “Energy - Total [Hot Water Tank]” (entity_id = sensor.total_hotwatertank_energy)
I then created a Utility Meter helper that uses the data from “sensor.total_hotwatertank_energy” and resets daily. I called this one “Energy - Daily [Hot Water Tank]” with an entity_id of “sensor.daily_hotwatertank_energy”. I then added this entity to one of my dashboards I am currently building.
I realized on Sunday morning when I was checking on this that it was reporting in Wh instead of kWh, and the realized that I had not changed the A2 and B2 energy_this_month entities to report kWh instead of the default Wh, as I had done for the “main” energy entities (A1 and B1)
I made the change, and now the “sensor.total_hotwatertank_energy” entity is reporting correctly in kWh, but the “sensor.daily_hotwatertank_energy” is still reporting the Wh value, though says it is kWh.
For example, as I write this, sensor.total_hotwatertank_energy is reporting 12.89 kWh and sensor.daily_hotwatertank_energy is reporting 3,154.22 kWh – which is obviously incorrect.
I have tried the following, all with failure, resulting in that 3,100+ number continuing to appear:
- Delete and re-add the Utility meter (value would reappear after changing the entity_id to “sensor.daily_hotwatertank_energy”.
- Run the “Purge Entity Data” from Developer Tools
- Add a new Utility Meter but leave it’s entity_id alone – in this case,t he kWh value appears to be correct. Trying to rename the entity_id to something like “sensor.daily_hotwater_tank_energy” or “sensor.daily_hotwatertnk_energy” results in the 3,100+ value coming back.
How do I delete this data once and for all so the Helper can “start fresh”? For consistency, I would like to keep the entity_id of “sensor.daily_hotwatertank_energy”.
Thanks! ![]()
