Utility Meter | Not storing correct daily and monthly values for only one sensor
Hiya,
I have several Xiaomi zigbee sockets with power monitoring but the utility_meter does not seem to like the one connected to my server rack.
The last 24hrs shows fairly constant use between 150 ~ 170w.
However, the daily and monthly store is way off.
113.15 Watts for the day is not right when the use is ~166Wh, ~3,984Wh for a 24hr period. Here is the code which is the same as my five other xiaomi sockets that are all reporting their values correctly.
  server_cabinet_d:
    source: sensor.xiaomi_server_power
    cycle: daily
  server_cabinet_m:
    cycle: monthly
    xiaomi_server_power:
      friendly_name: Server Consumption
      value_template: "{% if states.switch.server %}
          {{ states.switch.server.attributes.load_power }}
        {% else %}
          unknown
        {% endif %}"
      unit_of_measurement: 'W'
So they question is. Why would just one utility_meter be off when the data appears to be getting into HA?
You must use the utility_meter integration with sensors that provide energy (Wh) not with sensors that provide power (W)
