Utility Meter - Reset Offset not in UI once created
I have created quite a few utility meters, and I didn’t set any offset so they would reset at midnight (Daily)
But I see they are doing it at 00:20 instead, I went to the utility meter options in the UI (Helpers) and the settings for the offset are not there, they sem to only be during creation, is there a way for me to ensure this meters reset at midnight ? how do I edit an already created meter that was done via the UI helper ?
Carlos
If you want to check the offset this may help you Modify Utility meter after initial set up - #2 by Steve61
When you want to reset it manually create an automation with the action utility_meter.reset and let it run at a defined time
