Hello, I would like to use the Utility Meter and only have one tariff. In the documentation I read that the tariff is “optional”, but in the settings I have to choose a tariff (required), WHY?
Where can I create tariffs?
You can’t have one tariff, tariffs are about the ability to switch between different tariffs (e.g. peak and off-peak energy). You can’t switch from one tariff to the same tariff. So for one tariff just use no tariffs.
Why is tariffs not optional?
Thank’s
You need to set the reset cycle (Zähler-Reset-Zyklus). The red mark on the tariffs seems to be a bug.
