Utility Meters not reset after restoring from backup
My HA crashed due to SSD failure on July 2nd, and my last full backup was on June 30th.
After I restored from the backup, I found that all my monthly Utility Meter entities were not reset to start from July 1st. Instead, they continued to accumulate from the June values.
Is there a way to fix this? or is there a configuration setting to prevent this from happening?
When you restore from a backup the values will revert to whatever they were when you made the backup. There is no way to stop that happening.
You can use the utility meter calibrate action in Developer Tools → Actions to set your utility meters to any value.
Yes I can write some script to set them using the utility_meter.calibrate action. Not important at the moment.
IMHO, the Utility Meter is too dumb. I have some other integrations with monthly entity values; they all reset themselves to 0 on July 2nd after I restored from the backup. (The value on July 1st was the same as that of June 30th which is expected).
There’s nothing “dumb” about it.
When you restore a backup you restore the database too. So all sensors get the state they had when the backup was made. That is what restoring a backup does.
I meant that the algorithm for Utility Meter (UM) helpers may have a bug for this scenario.
e.g. On June 30 (the last backup), UM monthly energy had value 120 kWh. So on July 2, when I restored from backup, the UM monthly energy has value 120 kWh but it SHOULD check the last timestamp which was June 30 and reset to 0 since July 2 is a new month.
I have a Tapo energy monitoring plug which has a month energy reading. It reset itself to 0 on July 2 after I restored. This value is probably stored in the plug and wasn’t affected by HA’s “fauty” UM algorithm.
Integrations don’t have any awareness if they have been restored from backups or not.
It is up to you to sort that out.
Yeh. I may dig into the code to see how the Utility Meter is implemented. It doesn’t seem right not to be able to handle such a simple scenario.
It’s not a simple scenario. It is a very specific one. By all means submit a PR for it though.
A utility meter should have a last_reset and a next_reset attribute. After the restore (perhaps during startup), did the next_reset attribute get changed to the next month? If so, it would make sense to modify that code so that when the next_reset attribute is changed, the utility meter is reset at the same time. Even if it is past the datetime when the reset is supposed to occur.
If the next_reset attribute didn’t get changed and still reflects a datetime in the past, then that seems like a bug.
I agree that there is an issue there. Not just monthly and it would affect any timefame. (such as restoring a backup from last week will affect the weekly UM).
I have opened an issue with dev and hopefully someone will take a look at it.
