Utility scripts to emulate run-with-error-state and retry-on-errors
See my blog post HomeAssistant: Gracefully detecting and retrying on errors in YAML scripts for background and pure-YAML approximations.
In particular the python_script are the following:
Python script files
python_scripts/services.yaml
actions_with_error_state:
  name: Call Actions returning Error State
  icon: mdi:alert-circle-check-outline
  description: >-
    Invoke the given action list, *returning* whether the given action list
    succeeded or information about the failing error.
    Return structure:
      * `ok` (boolean): `true` if all actions succeeded, `false` otherwise
      * `error` (`None` or object): If an action failed, information about the error
         * `action` (string): Name of the failing action
         * `idx` (integer): 0-based index of the failing action in the list of actions
         * `exc` (exception): Caught service exception, can be stringified to get error message
  fields:
    actions:
      name: Actions to execute
      selector:
        action: {}
      required: true
actions_with_retries:
  name: Call Actions and Restart on Error
  icon: mdi:repeat-variant
  description: >-
    Repeats the given action steps until they either succeed or the number of
    retries has been exhausted.
    Return structure:
      * `ok` (boolean): `true` if all actions succeeded at some point, `false` otherwise
      * `retries` (integer): How often the actions were retried before succeeding (in range 0 to `retries`)
    If `fail_on_error` is true, this action will fail and no value is returned.
  fields:
    actions:
      selector:
        action: {}
      required: true
    retries:
      name: Number of Retries
      description: >-
        How often to retry *all* given actions before returning the first
        encountered error.
      selector:
        number:
          min: 1
      default: 3
    delay:
      description: >-
        Delay between retries of the action list.
      selector:
        duration:
          enable_millisecond: true
      default:
        hours: 0
        minutes: 0
        seconds: 1
        milliseconds: 0
    fail_on_error:
      name: Fail on Too Many Retries
      description: >-
        Note that you must still set a “Response Variable” when using this
        option or reported errors will not cause the calling script to exit.
      selector:
        boolean: {}
      default: false
python_scripts/actions_with_error_state.py
actions = data["actions"]  # Required action list
for idx, action in enumerate(actions):
	domain, name = action["action"].split(".", 1)  # "light.turn_on"
	payload = action.get("data", {})
	payload.update(action.get("target", {}))
	try:
		logger.info(f"Running action “{domain}.{name}”")
		hass.services.call(domain, name, payload, blocking=True)
	except Exception as exc:
		logger.warning(f"Action “{domain}.{name}” failed: {exc}")
		output["ok"] = False
		output["error"] = {"action": action["action"], "idx": idx, "exc": exc}
		break
else:
	output["ok"] = True
	output["error"] = None
python_scripts/actions_with_retries.py
retries = data.get("retries", 3)
delay = data.get("delay", 1)
fail_on_error = data.get("fail_on_error", False)
# Convert delay to fraction of second without violating sandbox
try:
	delay = float(delay)
except TypeError:
	delay = datetime.timedelta(
		hours = delay.get("hours", 0),
		minutes = delay.get("minutes", 0),
		seconds = delay.get("seconds", 0),
		milliseconds = delay.get("milliseconds", 0),
	).total_seconds()
first_error = None
for retry in range(retries):
	# Call `actions_with_error_state` to perform failable action run
	result = hass.services.call(
		"python_script", "actions_with_error_state",
		{ "actions": actions },
		blocking=True,
		return_response=True,
	if result["ok"]:
		# Forward success with added retry count
		output.update(result)
		output["retries"] = retry
		break
	# Save first error to forward it in case of ultimate failure
	if first_error is None:
		first_error = result
	# Apply delay only if not the last iteration
	if retry < retries - 1:
		time.sleep(delay)
# Handle if `break` was not reached / we are out of retries
else:
	# Forward first encountered error either as exception (“action failure”)
	# or structured valued interpretable by caller
	if fail_on_error:
		raise first_error["error"]["exc"]
	else:
		output.update(first_error)
		output["retries"] = retries
Usage
Example usage would be:
alias: "Door Bell: Send and Dismiss Notification (Background Task)"
icon: mdi:alarm-bell
sequence:
  - alias: "Ntfy: Publish Notification (with Retries)"
    action: python_script.actions_with_retries
      actions:
        - action: ntfy.publish
            priority: "5"
            sequence_id: doorbell
            tags:
              - bell
            title: Doorbell
            message: Doorbell button has been pressed
            device_id: be3fc64c497985de2d8705e856a9d3fb
      fail_on_error: true
    response_variable: result  # Unused variable, but property is required for failure to be reported
  - delay:
      hours: 0
      minutes: 1
      seconds: 0
      milliseconds: 0
  - alias: "Ntfy: Dismiss Notification (with Retries)"
      actions:
        - action: ntfy.clear
          enabled: true
      delay:
        hours: 0
        minutes: 0
        seconds: 1
        milliseconds: 0
      retries: 3
      fail_on_error: true
mode: restart
See the blog post for more details!
