Valetudo Card Syntax Help (Multiple Vacuums)
Hi all,
Hoping someone might be able to assist in what the proper syntax might be in the Valetudo/HA documentation for Home Assistant’s Lovelace card & scripts.yaml
It’s straightforward with only one Valetudo vacuum instance, but not sure the best way to go about adding the proper YAML syntax for more than one.
As far as I can tell, their documentation for HA’s YAML modification to show this would be in the Lovelace dashboard card, and scripts.yaml, but running into multiple roadblocks (mentally) on how this card build-out scales beyond one vacuum.
Thank you,
Karson
