Nothing of relevant in logs, telegram token problems, automation that not find switch or old integration not working anymore…
Update "None" caused error: "Conflict: terminated by other getUpdates request; make sure that only one bot instance is running"
23:34:02 – (ERRORE) Telegram bot - il messaggio si è verificato per la prima volta alle 19:00:46 e compare 513 volte
Error while getting Updates: Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
23:34:02 – (ERRORE) /usr/local/lib/python3.11/site-packages/telegram/ext/updater.py - il messaggio si è verificato per la prima volta alle 19:00:46 e compare 513 volte
Unable to find referenced entities switch.notturne_viale, switch.scala_sopra or it is/they are currently not available
21:14:49 – (AVVISO) helpers/service.py
TemplateError('TypeError: unsupported operand type(s) for /: 'NoneType' and 'int'') while processing template 'Template<template=({{ state_attr('sensor.power_per_minute', 'total') / (1000 * 60) }}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.realtime_power_enel'
19:00:25 – (ERRORE) helpers/template_entity.py
Error while processing template: Template<template=({{ state_attr('sensor.power_per_minute', 'total') / (1000 * 60) }}) renders=2>
19:00:25 – (ERRORE) helpers/template.py
Error in 'Lavatrice ON' trigger: In 'numeric_state' condition: no entity specified
19:00:25 – (AVVISO) Home Assistant Core Integration - il messaggio si è verificato per la prima volta alle 19:00:24 e compare 3 volte
Failed to generate automation from blueprint: Failed to load blueprint: Unable to find vorion/create-automated-backups-every-day.yaml
19:00:24 – (ERRORE) Automazione - il messaggio si è verificato per la prima volta alle 19:00:19 e compare 3 volte
Tomorrow I fix all problems found in logs and then I retry to search my lost switches
Ok fixing every problem found in log solved my issue.
I still not understand why… because no-one error was directly related with my issue, by the way thanks at all and happy HA!
