Validation of zwave door lock
I just picked up the kwikset 916 zwave lock and it’s working beautifully, but I was hoping somebody else had this lock setup and can confirm some of the entities that show up.
currently it’s showing:
binary_sensor.node_6_the_current_status_of_the_door - which is OPEN (not sure why, don’t really care since I have a door sensor installed anyways but seems strange it’s showing open when closed)
binary_sensor.node_6_access_control_lock_jammed - this is always set to ON
For the lock jammed status is it suppose to be always ON, seems weird that it’s ON instead of OFF.
Again the lock works perfectly fine and there are no issues but wanted to see if there is something wrong with my setup.
I am experiencing the exact same issue. Not causing any issues so far, but I’m only a week into HA and haven’t done much with it.
I am seeing this in the logs though. I don’t know if the log is reporting the open door status at the very end or if HA is giving that.
2022-04-14T04:27:09.909Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ transmit options: 0x25
                                  │ callback id:      103
                                  └─[SecurityCCNonceGet]
2022-04-14T04:27:09.918Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:11.170Z DRIVER « [REQ] [SendData]
                                    callback id:     103
                                    transmit status: OK
2022-04-14T04:27:11.185Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                  └─[SecurityCCNonceReport]
                                      nonce: 0x85bea47c38a00491
2022-04-14T04:27:11.193Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      104
                                  └─[SecurityCCCommandEncapsulation]
                                    │ nonce id: 133
                                    └─[DoorLockCCOperationSet]
                                        target mode: Unsecured
2022-04-14T04:27:11.205Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:11.233Z DRIVER « [REQ] [SendData]
                                    callback id:     104
                                    transmit status: OK
2022-04-14T04:27:13.949Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
2022-04-14T04:27:13.966Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ transmit options: 0x05
                                  │ callback id:      105
                                      nonce: 0xc0fd66a4a3717b7b
2022-04-14T04:27:13.976Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:13.998Z DRIVER « [REQ] [SendData]
                                    callback id:     105
                                    transmit status: OK
2022-04-14T04:27:14.023Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                    │ sequenced: false
                                    └─[NotificationCCReport]
                                        notification type:   Access Control
                                        notification status: 255
                                        notification event:  RF unlock operation
2022-04-14T04:27:16.245Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      106
2022-04-14T04:27:16.254Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:16.275Z DRIVER « [REQ] [SendData]
                                    callback id:     106
                                    transmit status: OK
2022-04-14T04:27:16.290Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      nonce: 0x8efab4723512eff1
2022-04-14T04:27:16.298Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      107
                                    │ nonce id: 142
                                    └─[DoorLockCCOperationGet]
2022-04-14T04:27:16.311Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:16.335Z DRIVER « [REQ] [SendData]
                                    callback id:     107
                                    transmit status: OK
2022-04-14T04:27:16.364Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
2022-04-14T04:27:16.379Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      108
                                      nonce: 0x1898d5bee727eeff
2022-04-14T04:27:16.389Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:16.412Z DRIVER « [REQ] [SendData]
                                    callback id:     108
                                    transmit status: OK
2022-04-14T04:27:16.438Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                    │ sequenced: false
                                    └─[DoorLockCCOperationReport]
                                        current mode:           Unsecured
                                        active outside handles: true, true, true, true
                                        active inside handles:  true, true, true, true
                                        latch status:           open
                                        bolt status:            unlocked
                                        door status:            open
2022-04-14T04:27:49.512Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      109
2022-04-14T04:27:49.521Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:50.773Z DRIVER « [REQ] [SendData]
                                    callback id:     109
                                    transmit status: OK
2022-04-14T04:27:50.787Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      nonce: 0xb815d23b9479e4e8
2022-04-14T04:27:50.789Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      110
                                    │ nonce id: 184
                                        target mode: Secured
2022-04-14T04:27:50.800Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:50.826Z DRIVER « [REQ] [SendData]
                                    callback id:     110
                                    transmit status: OK
2022-04-14T04:27:53.479Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
2022-04-14T04:27:53.495Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      111
                                      nonce: 0xd1f271dfdb46e2fc
2022-04-14T04:27:53.506Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:53.527Z DRIVER « [REQ] [SendData]
                                    callback id:     111
                                    transmit status: OK
2022-04-14T04:27:53.552Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                    │ sequenced: false
                                        notification event:  RF lock operation
2022-04-14T04:27:55.840Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      112
2022-04-14T04:27:55.849Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:55.870Z DRIVER « [REQ] [SendData]
                                    callback id:     112
                                    transmit status: OK
2022-04-14T04:27:55.886Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                      nonce: 0xdaaa211cb9623ee0
2022-04-14T04:27:55.890Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      113
                                    │ nonce id: 218
2022-04-14T04:27:55.900Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:55.925Z DRIVER « [REQ] [SendData]
                                    callback id:     113
                                    transmit status: OK
2022-04-14T04:27:55.954Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
2022-04-14T04:27:55.967Z DRIVER » [Node 014] [REQ] [SendData]
                                  │ callback id:      114
                                      nonce: 0xdacc6f7d80a12faa
2022-04-14T04:27:55.977Z DRIVER « [RES] [SendData]
                                    was sent: true
2022-04-14T04:27:55.999Z DRIVER « [REQ] [SendData]
                                    callback id:     114
                                    transmit status: OK
2022-04-14T04:27:56.030Z DRIVER « [Node 014] [REQ] [ApplicationCommand]
                                    │ sequenced: false
                                        current mode:           Secured
                                        active outside handles: false, false, false, false
                                        active inside handles:  false, false, false, false
                                        latch status:           open
                                        bolt status:            locked
                                        door status:            open
