zmechu
January 14, 2023, 10:29pm
1
Hello!
I have problem (simple I think) which can’t handle.
Have PV installation connected to HA with REST
- platform: rest
resource: http://xxxxx
json_attributes:
- flg
- vac
value_template: "{{ value_json.flg}}"
and template:
sensors:
PV_vac1:
friendly_name: "PV ACF1-V"
value_template: "{{ (state_attr('sensor.PV', 'vac')[1] | float(0) / 10)}}"
unit_of_measurement: "V"
Works fine during day (returns proper value), but after sunset return unknown or unavailable.
My question is: how to change my config which returns me value when value exist or “0” if sensor is unknown/unavailable? Found few ideas, but didn’t fit to my config…
Thanx!
petro
(Petro)
January 14, 2023, 10:32pm
2
Need some more info. What does the attribute vac look like after sunset?
zmechu
January 14, 2023, 10:51pm
3
now (no sun):
sensor. pv_vac1: unavailable
My rest sensor is web page with data. When sunset, webpage is unavaiable and sensor data cant be read.
petro
(Petro)
January 14, 2023, 10:56pm
4
no, The rest sensor w/ the vac
attribute, sensor.pv
petro
(Petro)
January 14, 2023, 11:00pm
5
ah ok,
{{ ((state_attr('sensor.PV', 'vac') or [0, 0])[1] / 10)}}
zmechu
January 17, 2023, 7:39am
6
Hello! Thanks for answer!
Seems to be 50% working Entity doesn’t return now “unknown” or “unavailable” status, which is fine! But didn’t return proper value - seems to be “0,0V” always…
petro
(Petro)
January 17, 2023, 12:23pm
7
make sure the entity_id is lowercase. It shouldn’t ever be 0 unless vac
is emtpy. Can you verify that the attribute has values? I’m making guesses to how it should work based on your code. If your original code was wrong, then so will my code.
zmechu
January 17, 2023, 10:37pm
8
Well, my full config:
- platform: rest
scan_interval: "00:00:10"
device_class: energy
state_class: measurement
value_template: "{{ value_json.pac | float / 1000 | round(2) }}"
unit_of_measurement: "kW"
- platform: rest
resource: resource: http://xxxxx
scan_interval: "00:01:00"
state_class: total_increasing
value_template: "{{ value_json.eto | float / 10}}"
unit_of_measurement: "kWh"
- platform: rest
value_template: "{{ value_json.etd | float / 10}}"
- platform: rest
value_template: "{{ value_json.tmp | float / 10}}"
unit_of_measurement: "C"
- platform: rest
json_attributes:
- flg
- tim
- pac
- etd
- hto
- eto
- vac
- tmp
- iac
- vpv
- ipv
- fac
- err
sensors:
falownik_vac3:
friendly_name: "PV ACF3-V"
value_template: "{{ (state_attr('sensor.pv', 'vac')[0] | float(0) / 10)}}"
falownik_vac1:
value_template: "{{ ((state_attr('sensor.pv', 'vac') or [0, 0])[1] / 10)}}"
falownik_vac2:
friendly_name: "PV ACF2-V"
value_template: "{{ ((state_attr('sensor.pv', 'vac') or [0, 0])[2] / 10)}}"
falownik_iac3:
friendly_name: "PV ACF3-A"
value_template: "{{ (state_attr('sensor.pv', 'iac')[0] | float(0) / 10)}}"
unit_of_measurement: "A"
falownik_iac1:
friendly_name: "PV ACF1-A"
value_template: "{{ (state_attr('sensor.pv', 'iac')[1] | float(0) / 10)}}"
falownik_iac2:
friendly_name: "PV ACF2-A"
value_template: "{{ (state_attr('sensor.pv', 'iac')[2] | float(0) / 10)}}"
falownik_vpv1:
friendly_name: "PV PV1-V"
value_template: "{{ (state_attr('sensor.pv', 'vpv')[0] | float(0) / 10)}}"
falownik_vpv2:
friendly_name: "PV PV2-V"
value_template: "{{ (state_attr('sensor.pv', 'vpv')[1] | float(0) / 10)}}"
falownik_ipv1:
friendly_name: "PV PV1-A"
value_template: "{{ (state_attr('sensor.pv', 'ipv')[0] | float(0) / 100)}}"
falownik_ipv2:
friendly_name: "PV PV2-A"
value_template: "{{ (state_attr('sensor.pv', 'ipv')[1] | float(0) / 100)}}"
falownik_hto:
friendly_name: "PV Czas Pracy"
value_template: "{{ (state_attr('sensor.pv', 'hto') | float(0) / 10)}}"
unit_of_measurement: "h"
falownik_err:
friendly_name: "PV Awaria"
value_template: "{{ state_attr('sensor.pv', 'err') }}"
unit_of_measurement: ""
I’ve been trying to edit “falownik_vac1” and “falownik_vac2” myself.
petro
(Petro)
January 17, 2023, 10:40pm
9
well vac2 will never work with the default the way it is. 1 should work fine
Still, that doesn’t help when I can’t see what data is in the attribute itself
petro
(Petro)
January 18, 2023, 1:20am
11
No, the source sensor that has the vac
attribute.
zmechu
January 19, 2023, 10:27am
12
OK, got it. Sorry for delay, I’ve been waiting for sun Raw data from PV:
{"flg":1,"tim":"20230119112439","tmp":154,"fac":5000,"pac":114,"sac":114,"qac":0,"eto":39850,"etd":3,"hto":3350,"pf":32,"wan":0,"err":0,"vac":[2434,2439,2429],"iac":[4,4,4],"vpv":[4114,0],"ipv":[47,0],"str":[]}
petro
(Petro)
January 19, 2023, 1:23pm
13
and what does the vac
attribute sesnor.pv
show when the information is not populated? It seems as if the or
in the template I provided is not working, which doesn’t make sense.
zmechu
January 19, 2023, 5:48pm
14
Resource of sensor is http page (http://IP/xxxxx ), PV system returns this "
{“flg”:1,“tim”:“20230119112439”,“tmp”:154 […]" data. When PV is offline, its returns nothing (http timeout)
petro
(Petro)
January 19, 2023, 6:02pm
15
Downs sensor.pv go unavailable during that time?
zmechu
January 19, 2023, 7:47pm
16
yep…
Got error log:
Logger: homeassistant.components.rest.data
Source: components/rest/data.py:83
Integration: RESTful (documentation, issues)
First occurred: 11:58:53 (3812 occurrences)
Last logged: 20:45:45
Error fetching data: http://xxxxx failed with Server disconnected without sending a response.
Error fetching data: http://xxxxx failed with All connection attempts failed
zmechu
January 22, 2023, 11:13pm
17
Another question: why vac1 works fine and vac2 doesn’t? Syntax is the same…
