Value template, modify date format from restful sensor
Hi All,
I’ve got a sensor pulling using restful, the value returned is a date format as follows
“2020-01-01”
I want to convert it to “01/01/2020” style but can’t get the custom date format to work, any ideas? It just returns “none”
{% set date = states('sensor.grey_bin') | regex_replace(find='"', replace='', ignorecase=False) %}
{{ as_timestamp(date) | timestamp_custom("%d/%m/%y", True) }}
n.b. the data comes back with double quotes hence the strip.
Try:
{{ strptime(states('sensor.grey_bin'), '"%Y-%m-%d"').strftime('%d/%m/%y') }}
or split and reverse it.
{{ states('sensor.grey_bin')[1:-1].split('-') | reverse | join('/') }}
Both do the same thing. @pnbruckner’s will give you more flexability if you want to do something like month day year.
Thanks Phil,
I’m getting Error rendering template: UndefinedError: ‘str object’ has no attribute ‘strftime’.
Can;t figure out why
Probably because states('sensor.grey_bin') is not returning a string formatted like you said. What do you get if you enter the following in the Template Editor?
{{ states('sensor.grey_bin') }}
I get “2020-01-13”
Maybe the quotes are different? Looks like your sensor.grey_bin value might have “ and ” instead of " and " ??
Maybe change @pnbruckner’s solution to:
{{ strptime(states('sensor.grey_bin'), '“%Y-%m-%d”').strftime('%d/%m/%y')
Just a guess.
Yeah, hard to say. @samtwilliams, when you post that sort of thing, please format it properly…
abc
Sorry, my bad. SO its not the double quotes as this also fails;
{% set date = '"2020-01-01"' %}
{{ strptime(states(date), '"%Y-%m-%d"').strftime('%d/%m/%y') }}
Right, but the value of {{ states('sensor.grey_bin') }} you pasted above doesn’t have SHIFT-’ generated " quotes, but different ones. Maybe a quick screen snip, like @pnbruckner requested earlier of {{ states('sensor.grey_bin') }} in the template editor.
Need its EXACT value to know what mask to use in the strptime function.
Your post above:
does not contain " type quotes, which your post above does:
That fails because the states() function takes as a parameter an entity_id, and '"2020-01-01"' is not an entity_id. Can you post what I asked for, please?
"2020-01-13"
Thanks. BTW, I think you already noticed and compensated for it, but I left the ending }} off my suggestion. I just went back and fixed that post.
Ok, so what does the following give you in the Template Editor:
{{ strptime(states('sensor.grey_bin'), '"%Y-%m-%d"') }}
"2020-01-13"
Whoa! That’s weird. It works for me. How about this:
{{ strptime('"2020-01-13"', '"%Y-%m-%d"') }}
EDIT: FWIW, this is what I get:
2020-01-13 00:00:00
Which shows it’s converting the string to a Python datetime object. Can’t understand why it’s not for you.
Odd isn’t it. it like everything works except when you introduce the value from state.
2020-01-13 00:00:00
Ok, I give up. Use @petro’s suggestion. :slightly_smiling_face:
:rofl: ok thanks for Helping tho!.
Trying to format the date and this is what I have… works great in Developers tools but not in Studio Code and it keeps throwing this error:
  sensors:
    new_date:
      {{ states('sensor.date')[0:-1].split('-') | reverse | join('/') }}
Error:
Missed coma between flow collection entries
tried looking that up and still can’t figure out what’s missing here… suggestions?
Your yaml is incorrect. You’re missing value_template
