I have these Govee branded WiFi sensors that show temperature and humidity. Sadly the Govee API is pretty rubbish and it fails a lot which is causing my HA to show the sensors as either Unavailable or Unknown.
Looking for a bit of help configuring the value_template so it uses the previous “good” value rather than making the sensor come up as Unknown.
Existing code to pull from the API and format the data is:
- resource: https://openapi.api.govee.com/router/api/v1/device/state
method: POST
headers:
Content-Type: "application/json"
Govee-API-Key: "XXXXXXXXXXXXX"
payload: '{"requestId": "uuid", "payload": {"sku": "H5179", "device": "XXXXXXXX"}}'
scan_interval: 30
- name: "Garage Freezer Humidity"
value_template: "{{ value_json.payload.capabilities | selectattr('instance', 'equalto', 'sensorHumidity') | map(attribute='state.value.currentHumidity') | first }}"
device_class: humidity
unique_id: garage_freezer_govee_humidity
unit_of_measurement: "% RH"
- name: "Garage Freezer Temperature"
value_template: "{{ (((value_json.payload.capabilities | selectattr('instance', 'equalto', 'sensorTemperature') | map(attribute='state.value') | first) - 32) * 5 / 9) | round(2) }}"
device_class: temperature
unit_of_measurement: "°C"
unique_id: garage_freezer_govee_temperature
TIA.
