As a new user of Home Assistant, I bought a mold detector (Popp, 701202). This sensor should give information about the humidity and temperature.
I could add the device as a z-wave node, but unfortunately, I do only see a binary sensor in the entity list but no humidity and temperature. In the OZW.log, however, I see that the device gives information on the humidity and temperature.
What do I do wrong and how can I add the information to the front end of home assistant?
I am really not an expert but you have not had a response yet. I suspect the binary node means “detected/not detected” which will be one available device and there may be more.
Have a look in HA - Developer Tools - States and see if there are any other devices related to yours. You may have several and you are only seeing the binary one on the front screen.
Thanks a lot for your answer. I do not remember how I did exactly, but after another restart HA was suddenly fully recognizing the sensor. Maybe I will try to make it officially fully supported later. Not sure whether I will understand everything, but it might be nice to give it a try.
