VanMoof integration (ESPHome/BTProxy Presence+API)
Still no finished product, just showcasing the implementation
As I got one of those proprietary dutch bikes :bike: I wanted to implement it in a way in my homeassistant dashboard (Even the picture is generated from the API)
Presence detection (typycally i store it in the basement, where it can be charged etc.) so i added two lines to a BT-Proxy device (PoESP32/M5 Stack, but that could be anything else)
ESPHome-BT-Config
substitutions:
  vanmoof_s5_mac: "12:34:56:C0:FF:EE"
# Bluetooth settings
esp32_ble_tracker:
  scan_parameters:
    duration: 10s # https://github.com/esphome/issues/issues/1408#issuecomment-696834035
ble_client:
  - id: ble_vanmoof_s5
    auto_connect: false
    # No autoconnect, just a couple of checks: https://esphome.io/components/ble_client.html#ble-client-connect-action
    mac_address: ${vanmoof_s5_mac}
    on_connect:
      then:
        - lambda: |-
            ESP_LOGD("BLE", "VanMoof S5 verbunden");
    on_disconnect:
      then:
        - lambda: |-
            ESP_LOGD("BLE", "VanMoof S5 getrennt");
bluetooth_proxy:
  active: true # activate bluetooth proxy
binary_sensor:
  - platform: ble_presence
    name: "BLE Presence Vanmoof S5"
    icon: "mdi:bike"
So that results in not only the device to be triangulated (if used) by Bermuda BLE, but also to be detected in HA-Cards:
But now we will face the API in order to gain insights on the bike speed and odometer.
I assume that you want to fetch data for one bike only (so that could be simplified), if you got multiple bikes, you can do it more sophisticated with regex and search for the serialnumber.
Requirement: please add the vm-token as a secret. It can be generated using shell/powershell etc: generate vm-token
its just the username and password as base64:
printf ‘%s:%s’ “$username” “$password” | base64
configuration.yaml
rest:
  - resource: "https://my.vanmoof.com/api/v8/authenticate"
    #scan_interval: 28800 # 8h
    scan_interval: 14400 # 4h
    timeout: 30  # Reduzierter Timeout fĂźr bessere Reaktionszeit
    method: "POST"
    headers:
      Accept: "application/json"
      Authorization: !secret vm_token
      Api-Key: "fcb38d47-f14b-30cf-843b-26283f6a5819"
      - name: "VM Auth" # Token for Bike API and App Token
        unique_id: vanmoof_auth_token
        force_update: true
        value_template: "OK"
        json_attributes:
          - token
          - refreshToken
  - resource: "https://api.vanmoof-api.com/v8/getApplicationToken"
    scan_interval: 7200  # Alle 2 Stunden
    timeout: 30
    method: "GET"
    headers:
      Authorization: "Bearer {{ state_attr('sensor.vm_auth', 'token') }}"
      - name: "VM Application Token" # Used for rides API
        unique_id: vanmoof_app_token
        force_update: true
        json_attributes:
          - token
        availability: >
          {{ states.sensor.vm_auth.state == "OK" and
             state_attr('sensor.vm_auth', 'token') is not none and
             (as_timestamp(now()) - as_timestamp(states.sensor.vm_auth.last_updated)) < 14400 }}
  - resource: "https://my.vanmoof.com/api/v8/getCustomerData?includeBikeDetails"
    scan_interval: 31536000 # 1Y
    timeout: 30
    method: "GET"
    headers:
      - name: "VM API customer details"
        unique_id: vanmoof_api_cust
        json_attributes:
            - data
        availability: >
      - name: "VM User UUID"
        unique_id: vanmoof_data_uuid
        value_template: "{{ state_attr('sensor.vm_api_customer_details', 'data')['uuid'] }}"
        availability: >
      - name: "VM Bike0 ID"
        unique_id: vanmoof_data_bikes_0_id
        value_template: "{{ state_attr('sensor.vm_api_customer_details', 'data')['bikes'][0]['id'] }}"
        availability: >
      - name: "VM Bike0 frame number"
        unique_id: vanmoof_data_bikes_0_frame_number
        value_template: "{{ state_attr('sensor.vm_api_customer_details', 'data')['bikes'][0]['frameNumber'] }}"
        availability: >
  - resource_template: https://bikeapi.production.vanmoof.cloud/bikes/{{ states('sensor.vm_bike0_frame_number') }}/create_certificate
    scan_interval: 604800 # 1W
    timeout: 30
    method: "POST"
    payload: '{ "public_key" : "xxx }'
    headers:
      Accept: "*/*"
      Authorization: "Bearer {{ state_attr('sensor.vm_application_token', 'token') }}"
      Content-Type: "application/json"
      - name: "VM bike certificate"
        unique_id: vanmoof_api_bike_cert
        json_attributes:
            - created_at
            - expiry
            - certificate
        availability: >
            {{ states('sensor.vm_bike0_frame_number') is not none and
            state_attr('sensor.vm_application_token', 'token') is not none and
            (as_timestamp(now()) - as_timestamp(states.sensor.vm_application_token.last_updated)) < 7200 }}
  - resource_template: https://tenjin.vanmoof.com/api/v1/rides/{{ states('sensor.vm_user_uuid') }}/{{ states('sensor.vm_bike0_id') }}/weekly?limit=15
    scan_interval: 14400 # 8h
    timeout: 30
    method: "GET"
    headers:
      Accept: "*/*"
      Time-Zone: "Europe/Berlin"
      Accept-Language: "de_DE"
      - name: "VM ride stats"
        unique_id: vanmoof_api_rides
        icon: mdi:counter
        json_attributes:
            - carousel
        availability: >
            {{ states('sensor.vm_user_uuid') is not none and
            states('sensor.vm_bike0_id') is not none and
      - name: "VM total rides"
        unique_id: vanmoof_total_rides
        value_template: "{{ state_attr('sensor.vm_ride_stats', 'carousel')['summary']['totalRides'] }}"
        state_class: "total_increasing"
        availability: >
            {{ states.sensor.vm_application_token.state == "OK" and
      - name: "VM total distance"
        unique_id: vanmoof_total_distance
        unit_of_measurement: 'km'
        icon: mdi:map-marker-distance
        value_template: "{{ state_attr('sensor.vm_ride_stats', 'carousel')['summary']['totalDistance'] }}"
        availability: >
      - name: "VM average speed"
        unique_id: vanmoof_average_speed
        unit_of_measurement: 'kmh'
        icon: mdi:speedometer
        value_template: "{{ state_attr('sensor.vm_ride_stats', 'carousel')['summary']['averageSpeed'] }}"
        availability: >
      - name: "VM average distance"
        unique_id: vanmoof_average_distance
        value_template: "{{ state_attr('sensor.vm_ride_stats', 'carousel')['summary']['averageDistance'] }}"
        availability: >
      - name: "VM average duration"
        unique_id: vanmoof_average_duration
        unit_of_measurement: 'min'
        icon: mdi:timer-check-outline
        value_template: "{{ (state_attr('sensor.vm_ride_stats', 'carousel')['summary']['averageDuration'] | int / 60000) }}"
        availability: >
You can now fetch the bike/ride stats accordingly. The API is built with different authorization tokens.
  • There is one bearer-token, which is provided after signin in using the base64-ed username/password
  • Another one is the application token, used for the ride api, but also to generate a certificate for the bike
I would suggest to fetch the tokens using automations. (If the bike is at home, there is no need to fetch the api more often, but if its outside, you might generate new statistics in the ride API.
This is still not a finished product. The battery might be fetched using ESPHome and the encryption key. Feel free to use this as an inspiration for further investigations.
I got into those API-Endpoints using mitm-proxy and my android/iphone devices.
First of all: great work!
I noticed that the secret vm_token has to be written like: “Basic NpbHZlcmVudG…FuZEBnbWFpbC5jb206=”. With that I get a value in the sensor attribute of VM_auth. But then it stops… Other sensors state OK but the attributes are empty
When I test the rest commands online I get a result like { “token”: “abcdefghijklmnopqrstuvwxyz1234567890” }
Hey, when the Okay is written, then you will find it in the attributes. I do the fetch and refresh stuff using automations which I can also share!
The thing ist, upon first load there might not be tokens for the further actions, thats probably why the other steps fail.
Maybe there is someone who wants to do it as an integration, but thats some work, for sure.
Actually fetching the BLE Details with the encryption Key would be amazing. So far i was not able to dive into the sourcecodes, I just figured out how to do a simple BLE sensor, triangulation and the API fetch for stats.
Yes, interested in the automations!
I have different ones, here you go:
On boot
alias: Update VanMoof Tokens, APIs and cert (on Boot)
description: >-
  Fetch API on boot, this includes the Authorization Bearer, the application
  token, customer details, the ride API and the bike certificate
triggers:
  - trigger: homeassistant
    event: start
conditions: []
actions:
  - action: homeassistant.update_entity
    metadata: {}
      entity_id:
        - sensor.vm_auth
  - delay:
      hours: 0
      minutes: 0
      seconds: 15
      milliseconds: 0
    metadata: {}
      entity_id:
        - sensor.vm_api_customer_details
        - sensor.vm_application_token
  - delay:
      hours: 0
      minutes: 0
      seconds: 15
      milliseconds: 0
    metadata: {}
      entity_id:
        - sensor.vm_ride_stats
        - sensor.vm_bike_certificater
mode: single
Regular API-fetch (8 hours)
alias: VM Api regular fetch
description: >-
  Fetch API every 8 hours, this includes the Authorization Bearer,  the
  application token, customer details and the ride API
triggers:
  - trigger: time_pattern
    hours: /8
conditions: []
actions:
    metadata: {}
      entity_id:
        - sensor.vm_auth
  - delay:
      hours: 0
      minutes: 0
      seconds: 15
      milliseconds: 0
    metadata: {}
      entity_id:
  - delay:
      hours: 0
      minutes: 0
      seconds: 15
      milliseconds: 0
    metadata: {}
      entity_id:
mode: single
Renew bike cert (7 days)
alias: Renew bike certificate
description: Fetch new bike certificate every 7 days.
triggers:
    hours: "0"
conditions:
  - condition: time
    weekday:
      - fri
actions:
    metadata: {}
      entity_id:
mode: single
Update ride stats
alias: Update ride stats
description: >-
  Fetch the ride stats, thats a standalone automation, as it is not related to
  other automations. (Can be triggered by others though)
triggers: []
conditions: []
actions:
    metadata: {}
      entity_id:
mode: single
So based on those automations, i use the ride-stats automtion for getting more accurate detailt. When the bike left my home, i can use another automation to fetch it e.g. each two hours.
Please also note the delay in the inital fetch ( On boot)
Still issues here…
Sensors report “OK” but the attributes stay empty. No log messages.
Hey, you should be able to get values, i would try to debug.
“OK” is just the value, please check the attributes.
Some insights on Bluetooth - in the meantime I was able to extract basic information, like name and model:
ESPHome BLE Sensors
    icon: mdi:alphabetical
    entity_category: "diagnostic"
    # Versteckte ble_client-Sensoren, die nur zum Auslesen da sind
  - platform: ble_client
    internal: true                      # wird nicht an HA exported
    ble_client_id: ble_vanmoof_s5
    service_uuid: "87290102-3C51-43B1-A1A9-11B9DC38478B"
    characteristic_uuid: "6AA50002-6352-4D57-A7B4-003A416FBB0B"
    on_value:
      then:
        - if:
            condition:
              # nur weiterverarbeiten, wenn der String nicht leer ist
              lambda: |-
                return x.size() > 0;
            then:
              - text_sensor.template.publish:
                  state: !lambda |-
                    return x.c_str();
    internal: true
    characteristic_uuid: "6AA50003-6352-4D57-A7B4-003A416FBB0B"
    on_value:
      then:
        - if:
            condition:
              lambda: |-
            then:
                  state: !lambda |-
                    return x.c_str();
Great work!! I’m not that advance to implement it as this level, by sure hope that you keep working on this! Would be amazing to fetch the battery in to come assistant to start and stop schedule charging based on the battery
Thanks for all the effort, I got it to work.
Could we use the service_uuid and characteristic_uuid to get the battery level?
I think the data is encrypted, not clear how that is actually sent. Additionally, the Mac adress might change over time.
But you can retrieve the encryption key via API, so there is at least some hope for authenticated requests like unlock the bike, setting the bell etc.
I made the Vanmoof ‘app’ for Homey, and I have a rough version in HACS for the Vanmoof S1. It uses ble to connect and get the data.
If you need help I can provice you
I would love that. I have a VanMoof S2 and would like to get more data, such as battery percentage
Still struggling to get all the data. Do I need to fill in something at the “xxx”? Seems weird that there is no " at the end
    timeout: 30
    method: "POST"
Did some checks and it goes wrong in one of the steps before.
  - resource: "https://my.vanmoof.com/api/v8/getCustomerDataincludeBikeDetails"
    scan_interval: 9600
    timeout: 60
    method: "GET"
    headers:
        json_attributes:
            - "data"
        availability: >
Sensor state is “OK”, but the attributes stay empty.
In Postman I get the data:
    "data": {
        "uuid": "5d0e2111-fxxxxxxxxxxxxxxxxx",
        "name": "Exxxxxxxxxxxxx",
        "email": "exxxxxxxxxxxxx",
        "confirmed": true,
        "phone": "00000000000",
        "country": "NL",
        "bikes": [
                "id": 12345,
                "name": "VanMoof S5",
                "frameNumber": "SVSBLxxxxxx",
                "macAddress": null,
                "bleProfile": "ELECTRIFIED_2022",
                "controller": "2022",
                "eLock": true,
                "speaker": true,
                "smartmoduleCurrentVersion": null,
                "smartmoduleDesiredVersion": null,
                "highestAvailableSpeedLimit": null,
                "tripDistance": 0,
                "modelName": "B-05S-E01EU-XX",
                "modelColor": {
                    "name": "Gray",
                    "primary": "#929393",
                    "secondary": "#929393"
                "frameShape": "S",
                "customerRole": "owner",
                "permissions": [
                    "ADD_USER",
                    "FIRMWARE_UPDATES",
                    "REMOVE_USER",
                    "REPORT_FOUND",
                    "REPORT_STOLEN",
                    "SEND_STATISTICS",
                    "BACKUP_CODE",
                    "BIKE_NAME",
                    "VIEW_THEFT_CASES",
                    "ALARM_SETTINGS",
                    "COUNTRY_SETTINGS",
                    "LIGHTS",
                    "MOTOR_SUPPORT_LEVEL",
                    "UNLOCK",
                    "READ_VALUES",
                    "STOLEN_MODE",
                    "SWAP_SMARTMODULE"
                "isTracking": false,
                "stolen": {
                    "isStolen": false,
                    "dateStolen": null,
                    "status": "not_stolen",
                    "latestLocation": null
                "links": {
                    "thumbnail": "https://my.vanmoof.com/image/model/99",
                    "show": "https://my.vanmoof.com/api/v8/getBikeData/180271"
        "links": {
            "hash": "https://my.vanmoof.com/api/v8/getCustomerDataHash",
            "devices": "https://my.vanmoof.com/api/v8/getDevices",
            "resendConfirmation": null,
            "update": "https://my.vanmoof.com/api/v8/updateCustomer",
            "addBike": "https://my.vanmoof.com/api/v8/registerBikeToCurrentUser",
            "addFcmToken": "https://my.vanmoof.com/api/v8/registrationToken",
            "theftCases": "https://my.vanmoof.com/api/v8/getCurrentTheftCasesForCurrentUser"
        "bikeDetails": [
                "id": 12345,
                "frameNumber": "SVSBLXXXXXXX",
                "ownerName": "EXXXxXXxxXX",
                "tripDistance": 0,
                "macAddress": null,
                "changeBackupCode": true,
                "messageAvailable": false,
                "modelDetails": null,
                "modelColor": {
                    "name": "Gray",
                "frameShape": "S",
                "manufacturer": "pegatron",
                "updateMethod": "OAD (encrypted)",
                "eLock": true,
                "gsmModule": "4G",
                "speaker": true,
                "permissions": [
                    "ADD_USER",
                    "FIRMWARE_UPDATES",
                    "REMOVE_USER",
                    "REPORT_FOUND",
                    "REPORT_STOLEN",
                    "SEND_STATISTICS",
                    "BACKUP_CODE",
                    "BIKE_NAME",
                    "VIEW_THEFT_CASES",
                    "ALARM_SETTINGS",
                    "COUNTRY_SETTINGS",
                    "LIGHTS",
                    "UNLOCK",
                    "READ_VALUES",
                    "STOLEN_MODE",
                    "SWAP_SMARTMODULE"
                "key": null,
                "stolen": {
                    "isStolen": false,
                    "dateStolen": null,
                "hasPeaceOfMind": false,
                "peaceOfMind": null,
                "links": {
                    "hash": "https://my.vanmoof.com/api/v8/getBikeDataHash/xxxxxx",
    "hash": "34562465245645735473567"
Does the empty attribute have to do with the length of the output being >255 characters?
Hey, could you please check the json_attributes:
json_attributes:
          - data
so no quotation marks, thats what I configured.:
    timeout: 30
    method: "GET"
    headers:
        json_attributes:
          - data
        availability: >
Hi @3DJupp question, I got this all working and it is great. Only thing I have is that my vanMoof S5 seems to have a Random MAC address so I need to update the bluetooth config file an re-build and install it on my bluetooth proxy. Do you have the same problem?
Yes, the MAC adress seems to rotate.
How do you “fix” that? Every time installing a new “firmware” on the ESP?
Yeah, there is no dynamic way to do this
I don’t use the MAC address anymore for identification of my bike. I now use the service_uuid for presence this works great!
substitutions:
  friendly_name: VanMoof Bluetooth Proxy
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
esp32:
  board: esp32dev
  framework:
    type: esp-idf
logger:
  level: INFO # Keeps logs available via Home Assistant but not the web
api:
  reboot_timeout: 0s # Stops the reboot loop
  encryption:
    key: <random_key>
wifi:
  ssid: !secret wifi_ssid
  use_address: 192.x.x.x
  power_save_mode: none
esp32_ble_tracker:
  scan_parameters:
    interval: 320ms
    window: 30ms # Listen less to let the WiFi breathe
    active: false # Passive mode is 10x lighter on resources
binary_sensor:
    service_uuid: 'YOUR_BIKE_UUID'
    name: "VanMoof S5 Presence"
    device_class: presence
    filters:
      - delayed_off: 5min
bluetooth_proxy:
  active: true
now there is a fully working integration that works with s/a5 :slight_smile: GitHub - TimTheBeastNL/VanMoof-SA5-HomeAssistant ¡ GitHub
