Variable don't pass properly
Have a nice day 2025 to all.
I have a variable that i want to pass trough an automatisation.
At the beginning of the automatisation i set this:
variables:
  comm: descendre
then i want it to check the variable with the “choose” option:
choose:
  - conditions:
      - condition: template
        value_template: '{{ comm ==  descendre  }}'
But the result is always false.
Your code as written is comparing a variable comm, which does indeed contain the string "descendre", against another variable descendre, which is not defined.
The string to compare against must be marked as such with quotes, and the customary way in HA is to encase the template in double quotes and mark the strings within using single quotes. Thus:
choose:
  - conditions:
      - "{{ comm == 'descendre' }}"
Thanks for your reply.
I try the code bellow but it still doesn’t work.
  - conditions:
        value_template: "{{ comm == 'descendre' }}"
It’s weard, in execution history the quote are not place the same as in yaml file
You will have to post the entire automation YAML for a real verdict, but based on the screenshot only I would guess your problem is variable scope.
It looks like you are using a choose: right before to decide between several variables: to be set, but those variables will only ever live within their enclosing sequence:. Once you exit the sequence: those variables are gone.
For that to work, you need to eliminate the choose: and set your variables: at the top level. The conditions that determine which values to assign to the variables instead need to be written as templates.
alias: 3-VOLET-Voletvelux
description: ""
triggers:
  - entity_id: input_button.volet_velux
    trigger: state
  - entity_id: binary_sensor.cp_velux_contact
    to: "on"
    trigger: state
  - entity_id: input_button.volet_velux_stop
    trigger: state
  - entity_id: sensor.telecommande_volet_velux_action
    to: 1_single
    id: Monté télécommande
    trigger: state
    to: 3_single
    id: Déscente télécommande
    trigger: state
    to: 2_single
    trigger: state
conditions: []
actions:
  - target:
      entity_id:
        - switch.switch_cave_zigbe_l1
        - switch.switch_cave_zigbe_l2
    data: {}
    action: switch.turn_off
  - choose:
      - conditions:
          - condition: trigger
          - condition: state
            state: "off"
          - condition: state
            entity_id: input_boolean.volet_velux
            state: "off"
        sequence:
          - variables:
              comm: descendre
      - conditions:
          - condition: state
            state: "off"
        sequence:
          - variables:
              comm: descendre
      - conditions:
          - condition: state
            state: "off"
          - condition: state
            state: "on"
        sequence:
          - variables:
              comm: monter
      - conditions:
          - condition: state
            state: "off"
        sequence:
          - variables:
              comm: monter
      - conditions:
        sequence:
          - variables:
              comm: stop
  - choose:
      - conditions:
            value_template: "{{ comm == 'monter'}}"
        sequence:
          - target:
              entity_id: a01f5b18a3c4d958558fda05b36fa2cc
            data: {}
            action: switch.turn_on
          - target:
            data: {}
            action: input_boolean.turn_off
          - delay:
              hours: 0
              minutes: 0
              seconds: 50
              milliseconds: 0
          - target:
            data: {}
      - conditions:
        sequence:
          - target:
              entity_id: ffa7e3c63fc27f5c8ec98e418a105963
            data: {}
          - target:
            data: {}
            action: input_boolean.turn_on
          - delay:
              hours: 0
              minutes: 0
              seconds: 50
              milliseconds: 0
          - target:
            data: {}
mode: restart
Well, like I said, variable scope. You need to replace the whole first choose: block with the logic inside a variable template instead:
- variables:
    comm: >-
      {%- if trigger.id == 'bouton aveugle' and
      is_state('binary_sensor.cp_velux_contact', 'off') and
      is_state('input_boolean.volet_velux', 'off') -%}
        descendre
      {%- elif trigger.id == 'Déscente télécommande' and
      is_state('binary_sensor.cp_velux_contact', 'off') -%}
        descendre
      {%- elif trigger.id == 'bouton aveugle' and
      is_state('input_boolean.volet_velux', 'on') -%}
        monter
      {%- elif trigger.id == 'Monté télécommande' and
        monter
      {%- elif trigger.id == 'Stop' -%}
        stop
      {%- endif -%}
Many thanks. It work.
