Variable for time and day
I’m trying to build an automation and I have several variables.
I want that, depending on the time and day, the output is one thing or another.
I have used this variable
is_day_time: “{{ now().weekday() in range(0, 5) and now().hour >= 8 and now().hour < 24 }}”
Time 1 would be from Monday to Friday between 8 to 24
Time 2 would be mon-fri 24 to 8 and weekends
Does that variable work as intended? I think is not working
Copy-paste the following template into the Template Editor then change the values of the two variables to exercise the template and confirm it reports true only when you want.
{% set today = 2 %}
{% set hour = 9 %}
{{ 0 <= today <= 4 and 8 <= hour <= 23 }}
If it works to your satisfaction, you can use this:
{{ 0 <= now().weekday() <= 4 and 8 <= now().hour <= 23 }}
EDIT
Correction. Fixed upper bound of first arithmetic comparison. See Mayhem_SWE’s post below.
Why would you think it is not working? Seems fine to me. You can simplify the last two conditions:
{{ now().weekday() in range(0, 5) and 8 <= now().hour < 24 }}
Or use a schedule helper, which would allow you to an easy UI to edit activation times day by day.
Small correction, range(0, 5) is unintuitive and actually produces a list that does not include the ending value, so should be <= 4 :wink:
Ouch! I knew that yet just glossed over it. Thanks for bringing it to my attention. I’ll correct the example.
Thanks!
This was part of the variables in this automation
variables:
  grid_power: "{{ states('sensor.shellyemg3_8cbfea96acd8_em1_power') | int(0) }}"
  total_consumption: "{{ grid_power }}"
  max_grid_power_day: 4700
  max_grid_power_night: 6200
  charge_current: "{{ states('number.corriente_de_carga') | int(0) }}"
  charger_consumption: "{{ charge_current * 230 }}"
  is_day_time: "{{ now().weekday() in range(0, 5) and 8 <= now().hour < 24 }}"
  actual_free_power_day: "{{ max_grid_power_day - (total_consumption - charger_consumption) }}"
  actual_free_power_night: "{{ max_grid_power_night - (total_consumption - charger_consumption) }}"
  actual_free_power: |-
    {% if is_day_time %}
      {{ actual_free_power_day }}
    {% else %}
      {{ actual_free_power_night }}
    {% endif %}
With the following target
  entity_id: number.corriente_de_carga
  value: |-
    {% if actual_free_power >= 7360 %}
      32
    {% elif actual_free_power >= 7130 %}
      31
    {% elif actual_free_power >= 6900 %}
      30
    {% elif actual_free_power >= 6670 %}
      29
    {% elif actual_free_power >= 6440 %}
      28
    {% elif actual_free_power >= 6210 %}
      27
    {% elif actual_free_power >= 5980 %}
      26
    {% elif actual_free_power >= 5750 %}
      25
    {% elif actual_free_power >= 5520 %}
      24
    {% elif actual_free_power >= 5290 %}
      23
    {% elif actual_free_power >= 5060 %}
      22
    {% elif actual_free_power >= 4830 %}
      21
    {% elif actual_free_power >= 4600 %}
      20
    {% elif actual_free_power >= 4370 %}
      19
    {% elif actual_free_power >= 4140 %}
      18
    {% elif actual_free_power >= 3910 %}
      17
    {% elif actual_free_power >= 3680 %}
      16
    {% elif actual_free_power >= 3450 %}
      15
    {% elif actual_free_power >= 3220 %}
      14
    {% elif actual_free_power >= 2990 %}
      13
    {% elif actual_free_power >= 2760 %}
      12
    {% elif actual_free_power >= 2530 %}
      11
    {% elif actual_free_power >= 2300 %}
      10
    {% elif actual_free_power >= 2070 %}
      9
    {% elif actual_free_power >= 1840 %}
      8
    {% elif actual_free_power >= 1610 %}
      7
    {% elif actual_free_power >= 1380 %}
      6
    {% else %}
      0
    {% endif %}
action: number.set_value
But it’s not working. I had it working before adding the two time periods, so I though the issue was with that time template
