Variable syntax help require for "TOPIC"
Hi Guys,
I have a simple MQTT automation and need to chage the mqtt TOPIC: values but cannot get the syntax order correct.
This works well
topic: “cmnd/sonoff_53/color” and will send the MQTT to my Sonoff_53
but I wont to replace the sonoff_53 in the middle to a variable that is stored in ‘input_select.bulb_selector’
something like this ( which does not work )
Topic: “cmnd/{{ input_select.bulb_selector }} /color”
Any help on formatting this line would be great
Thanks Dave
Which does not work where?
Are you trying to set the command_topic of an MQTT component or is this part of an automation’s action (mqtt.publish) or what is it?
Sorry, Should have included a little more info. New to this forum , so just getting my head around its use…
This is part of the automation section and I am using the mqtt.publish
Change LED Bulb Color with Input Select
  • alias: Led Color Automation
    platform: state
    entity_id: input_number.slider_red, input_number.slider_green, input_number.slider_blue, input_number.slider_white
    • service: mqtt.publish
      data_template:
      payload: ‘{{ states.input_number.slider_red.state | int }},{{ states.input_number.slider_green.state | int }},{{ states.input_number.slider_blue.state | int }},{{ states.input_number.slider_white.state | int }}’
This snippit above works as it should by would like to change the sonoff_53 in the middle of the topic to a value that is stored in “input_select.bulb_selector”
This will do the trick:
topic: "{{ 'cmnd/' + states('input_select.bulb_selector') + '/color' }}"
Here it is in a formatted version of your automation:
  - alias: Led Color Automation
      platform: state
      data_template:
        payload: '{{ states.input_number.slider_red.state | int }},{{ states.input_number.slider_green.state | int }},{{ states.input_number.slider_blue.state | int }},{{ states.input_number.slider_white.state | int }}'
Hi 123
Worked like a charm, once I sorted my silly entity change errors, reboot modem which stopped sending any wifi and changed the bulbs back to the correct ones.
Now all I got to do is get my head around exactly whats going on with that line. I think Ive got the idea but have to admit it would have taken me a long time to work that one out.
Thanks Dave ( Happy Days )
