Variables and helpers dissapeared after last update
Since the update today as well the helpers and variable integration dissapeared. Does somebody has a solution?
Meanwhile the helpers returned, variable integration not.
See: 2024.7: Time to resize your cards! - Home Assistant
Upgrade to the latest version
2024.7.2 may have fixed the variable integration.issue. Also the author of that has released code to fix that as well.
Know that the fix to prevent custom integrations from causing these core problems involves a DB migration, so it may take a while. If you nave a huge DB, there also may be a space problem on your drive.
