VietNgoc
(Ngoc John)
June 2, 2025, 7:48pm
127
Vehicle Status Card v1.12.0
What’s Changed
This release introduces several highly requested features, UI enhancements, and internal improvements for a better user experience and customization flexibility.
New Features
Vertical Button Layout
Easily switch the button grid layout to vertical orientation for compact UIs. #125
Customizable Notification Badges
Buttons now support customizable notification badge styles, letting you highlight states more effectively. #126
Color Template for Indicator Groups Item
Indicator group items can now use color templates for enhanced visual clarity. #127
Tap Action for Range Info Entities
You can now define a tap action on range info entities for better interactivity.
Other Improvements
Map Marker now updates automatically when entity location changes.
Refactored action handler events and polished UI components for better responsiveness. #128
Full Changelog : v1.11.3…v1.12.0
VietNgoc
(Ngoc John)
June 2, 2025, 8:38pm
128
Hi, fixed in the relese v1.12.0
Is there something I am doing wrong to get this result ? The card is in a section and 3 columns wide:
If I pan right I get this:
If I resize the browser window, even slightly, it fills the card
Then back to the first image if I refresh the page or navigate away and back
Hello, sorry but I’m a newbie I can’t get the application to work. (version 1.12.0)
When I insert the various indicators they don’t appear on the dashboard
Furthermore in the layout configuration if I flag indicators or range info I see the preview but if I remove the flag the visualization disappears. (It seems to me that it should be the other way around)
Could someone post the yaml code of a working visualization to get some ideas?
There seems to be an issue with v1.12.0:
opened 03:41PM - 03 Jun 25 UTC
bug
### Short summary 📝
Vehicle card no longer shows in version 1.12.0
### Detaile… d description 📋
My vehicle card is configured as follows on Home Assistant 2025.5.3:
```yaml
type: custom:vehicle-status-card
button_card:
- button:
primary: Remote Start
secondary:
- entity: ""
attribute: ""
state_template: ""
icon: mdi:car-wireless
notify: ""
button_type: action
hide_button: false
card_type: default
default_card: []
custom_card: []
button_action:
entity: button.cooper_se_activate_air_conditioning
tap_action:
action: perform-action
perform_action: button.press
entity_id: button.cooper_se_activate_air_conditioning
hold_action:
action: none
double_tap_action:
action: none
- button:
icon: mdi:lock
primary: Lock Car
secondary:
entity: ""
attribute: ""
state_template: ""
button_type: action
hide_button: false
card_type: default
default_card: []
custom_card: []
button_action:
entity: lock.cooper_se_lock
tap_action:
hold_action:
action: none
double_tap_action:
action: none
layout_config:
button_grid:
rows: 2
columns: 2
swipe: true
hide:
button_notify: false
buttons: false
images: false
indicators: false
mini_map: false
range_info: false
map_address: false
theme_config:
mode: auto
theme: default
section_order:
- header_info
- images
- mini_map
- buttons
mini_map:
device_tracker: device_tracker.cooper_se
enable_popup: true
us_format: true
indicators:
single:
- entity: binary_sensor.cooper_se_check_control_messages
icon: ""
attribute: ""
action_config:
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
- entity: binary_sensor.cooper_se_connection_status
icon: ""
attribute: ""
action_config:
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
- entity: lock.cooper_se_lock
icon: ""
attribute: ""
action_config:
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
- entity: binary_sensor.cooper_se_windows
icon: ""
attribute: ""
action_config:
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
- entity: sensor.cooper_se_mileage
icon: ""
attribute: ""
action_config:
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
range_info:
- energy_level:
entity: sensor.cooper_se_charging_level_hv
attribute: ""
icon: ""
range_level:
entity: sensor.cooper_se_remaining_range_electric
attribute: ""
progress_color: "#004225"
charging_entity: sensor.cooper_se_charging_status
images:
- url: /api/image/serve/8ff59364976234fdf98ce0ef19547e89/original
title: MINI_SE.PNG
This configuration works in 1.11.3, in version 1.12.0 the card does not display. Also, if trying to add a new Vehicle Status Card, visual editor goes blank upon adding an indicator.
### Version 📦
v1.12.0
### Environment 🌐
Chrome Windows 11, Edge Windows 11, Firefox Windows 11, Offical App on iOS
### Logs and screenshots 📂
This is the error displayed in the Chrome developer console:
vehicle-status-card.js?hacstag=8593716631120:4294 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'length')
at Rz._renderIndicators (vehicle-status-card.js?hacstag=8593716631120:4294:97)
at vehicle-status-card.js?hacstag=8593716631120:4292:22
at Array.map (<anonymous>)
at Rz._renderMainCard (vehicle-status-card.js?hacstag=8593716631120:4291:11)
at Rz.render (vehicle-status-card.js?hacstag=8593716631120:4288:45)
at Rz.update (vehicle-status-card.js?hacstag=8593716631120:22:256)
at Rz.performUpdate (vehicle-status-card.js?hacstag=8593716631120:11:4621)
at Rz.scheduleUpdate (vehicle-status-card.js?hacstag=8593716631120:11:4139)
at Rz._$EP (vehicle-status-card.js?hacstag=8593716631120:11:4047)
_renderIndicators @ vehicle-status-card.js?hacstag=8593716631120:4294
(anonymous) @ vehicle-status-card.js?hacstag=8593716631120:4292
_renderMainCard @ vehicle-status-card.js?hacstag=8593716631120:4291
render @ vehicle-status-card.js?hacstag=8593716631120:4288
update @ vehicle-status-card.js?hacstag=8593716631120:22
performUpdate @ vehicle-status-card.js?hacstag=8593716631120:11
scheduleUpdate @ vehicle-status-card.js?hacstag=8593716631120:11
_$EP @ vehicle-status-card.js?hacstag=8593716631120:11
await in _$EP
requestUpdate @ vehicle-status-card.js?hacstag=8593716631120:11
set @ vehicle-status-card.js?hacstag=8593716631120:11
set hass @ vehicle-status-card.js?hacstag=8593716631120:4283
update @ hui-card.ts:191
performUpdate @ reactive-element.ts:1503
scheduleUpdate @ reactive-element.ts:1399
_$EP @ reactive-element.ts:1371
await in _$EP
requestUpdate @ reactive-element.ts:1310
set @ reactive-element.ts:789
(anonymous) @ hui-section.ts:132
update @ hui-section.ts:131
t.performUpdate @ storage.ts:172
await in _$EP
(anonymous) @ hui-view.ts:266
update @ hui-view.ts:264
await in _$EP
updated @ hui-root.ts:524
_$AE @ reactive-element.ts:1552
performUpdate @ reactive-element.ts:1517
await in _$EP
j @ lit-html.ts:1983
_$AI @ lit-html.ts:1923
p @ lit-html.ts:1282
$ @ lit-html.ts:1636
_$AI @ lit-html.ts:1475
j @ lit-html.ts:2274
update @ lit-element.ts:171
await in _$EP
updatePageEl @ partial-panel-resolver.ts:97
update @ hass-router-page.ts:89
await in _$EP
await in _$EP
await in _$EP
_updateHass @ hass-base-mixin.ts:50
_updateHass @ context-mixin.ts:107
(anonymous) @ connection-mixin.ts:235
n @ store.js:19
(anonymous) @ entities.js:74
(anonymous) @ entities.js:76
(anonymous) @ connection.js:23
_handleMessage @ connection.js:15
VietNgoc
(Ngoc John)
June 4, 2025, 7:26pm
132
Hi, it’s a common bug for leaflet maps when the element is not displayed yet. I’ve added a minor fix for this bug in the latest release,
fixed
VietNgoc
(Ngoc John)
June 9, 2025, 8:21pm
133
v1.13.0
What’s Changed
This release adds new layout and configuration features for range info and buttons, along with important display fixes and improvements for optional config handling.
New Features
Charging Template & Target Support
Add charging template and charge target support in the range info progress bar. #133
Range Info Layout Options
Add layout configuration for range info bars.#140
Transparent Button Background & State Colors
Support transparent background and state-specific color styling for buttons. Enhances visual customization for dynamic or themed designs. #142
Fixes
Fix: Adjust energy item display to include charging icon inside #139
Update tireConfig handling to support optional properties #143
Full Changelog : Comparing v1.12.1...v1.13.0 · ngocjohn/vehicle-status-card · GitHub
Can’t thank you enough for what you are doing! One of my all time favorite cards!!
