Velbus automation break since HA 2021.10
I’m using Home Assistant Core 2021.10.1. Since I upgraded from 2021.8.8 a lot of automations using the Velbus integration did break. All automations using the brightness setting of a dimmer now show up in the UI as “Unknown action”.
  - type: turn_on
    device_id: a0dc70f1a62edfeede820d7579d24e7e
    entity_id: light.dim_ch3_tv
    domain: light
    brightness_pct: 1
When I select the action drop down, the options are : Turn on, Turn off, Toggle, Increase and Decrease. But not an option for setting a brightness level anymore.
How can I set the brightness level of a light through the action of an automation in the UI ?
In addition, the Climate card is not working anymore which was linked to the temperature sensor of the Velbus VMBGPOD device.
Output of the log:
2021-10-08 18:13:33 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities climate.vloerverwarming
Same here.
any fix available?
Hi Thijs, for me all issues got resolved in later versions. Though, I’m not yet on 2021.12 yet. From which version did you upgrade ?
it all worked under 2021.9.6
last week i upgraded to 2021.12.1
and today to the latest 12.2 as a try to fix it.
Thijs
