I’m running 2 instances of HA. One runs on my Velbus Signum and the other on a dedicated PC. The last one I use for my home since the Velbus HA is limited.
When I change something in my Velbus configuration (VelbusLink) it also changes in the Velbus HA.
To get the changes take affect in the other HA, I try to run /development/action Velbus: empty cache. This gives me an error: Action velbus.clear_cache could not be performed. undefined
looking in the logs I see following error:
FileNotFoundError: [Errno 2] No such file or directory: ‘/config/.storage/velbuscache-01JMP9YXYD5EPDF5NDKNxxxxxx/15.json’
With Code Studio Server I can’t also find the file.
I have already deleted the Velbus Integration and installed it again. It then loads the devices and integrations, but this can’t be the solution everytime you change something?
Similar happens with Velbus: Scan.
On the other hand Velbus: Clock sync works.
Any idea?
Thx,
Rogier
