Velux Devices to HA
Hey,
im in a new apartment and it has 4 Velux blinds.
Each blind is controlled by an KLI 313 and also there got KUX 110 for each blind.
I want to add them into my HA, but is the only way to do that to buy an KLF 200?
Or are there any other devices / hacks to get them into my HA?
I dont want to add any zwave relais or somtehing like that.
Greetz
Markus
Hi!
You have 3 choices from what I understood:
Get an IO hub and then use this integration:
Or get a KFL200 and use the velux integration (local API)
Or get a Somfy hub and use the somfy integration (will be deprecated soon and then replaced by the overkiz one)
Thank you for your reply :slight_smile:
The IO Hubs are not that much cheaper than the KFL200. Since i only need it for the Velux Blinds, i would stay with the KLF200.
But if any one got another cheaper idea, go for it :slight_smile:
I don’t know where you live but in France we have this hub which is not that expansive:
https://boutique.orange.fr/accessoires/kit-de-connectivit-somfy
Im from Germany. So this one should work for Velux KLI 313 or KUX 110 with the Overkiz Intergation?
