Hi, I am trying to connect my Velux KLF200 to HA but I am getting this error all the time below. I have connected a LAN cable to KLF 200 and configured a static IP withing a closed range of på LAN and followed the setup instructions for the integration. What am I missing out?
Error during setup of component velux
File “/usr/src/homeassistant/homeassistant/setup.py”, line 235, in _async_setup_component
result = await task
File “/usr/src/homeassistant/homeassistant/components/velux/init.py”, line 39, in async_setup
await hass.data[DATA_VELUX].async_start()
File “/usr/src/homeassistant/homeassistant/components/velux/init.py”, line 84, in async_start
await self.pyvlx.load_scenes()
File “/usr/local/lib/python3.9/site-packages/pyvlx/pyvlx.py”, line 80, in load_scenes
await self.scenes.load()
File “/usr/local/lib/python3.9/site-packages/pyvlx/scenes.py”, line 51, in load
await get_scene_list.do_api_call()
File “/usr/local/lib/python3.9/site-packages/pyvlx/api/api_event.py”, line 21, in do_api_call
await self.send_frame()
File “/usr/local/lib/python3.9/site-packages/pyvlx/api/api_event.py”, line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File “/usr/local/lib/python3.9/site-packages/pyvlx/pyvlx.py”, line 66, in send_frame
await self.connect()
File “/usr/local/lib/python3.9/site-packages/pyvlx/pyvlx.py”, line 43, in connect
await self.connection.connect()
File “/usr/local/lib/python3.9/site-packages/pyvlx/connection.py”, line 87, in connect
self.transport, _ = await self.loop.create_connection(
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 1056, in create_connection
raise exceptions[0]
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 1041, in create_connection
sock = await self._connect_sock(
File “/usr/local/lib/python3.9/asyncio/base_events.py”, line 955, in _connect_sock
await self.sock_connect(sock, address)
File “/usr/local/lib/python3.9/asyncio/selector_events.py”, line 502, in sock_connect
return await fut
File “/usr/local/lib/python3.9/asyncio/selector_events.py”, line 537, in _sock_connect_cb
raise OSError(err, f’Connect call failed {address}’)
OSError: [Errno 113] Connect call failed (‘192.168.1.32’, 51200)
