Problem:
If I trigger “close shutter” while the window is open, the shutter starts closing immediately.
This is dangerous because it can physically damage the shutter if the window is not fully closed.
This in fact already happened, the frame of the roller shutter broke.
Additionally:
There is no reliable “stop” command available during movement
Commands are queued by the VELUX gateway, so sending:
close window
close shutter
results in the shutter closing first, then the window. This is the sequence to break the cover.
Expected behavior:
Home Assistant should allow safe sequencing, for example:
close window first
wait until closed
then close shutter
Or at least:
provide a built-in safeguard / option to prevent shutter closing when window is open
This is not just a convenience feature, but a safety issue that can lead to hardware damage.
Workarounds exist with automations, but they are unreliable due to command queueing and lack of stop control.
Request:
expose a reliable stop command if available
allow sequential execution (wait for state before next command)
or provide a built-in safety lock between related devices
Disclaimer: I am one of the “code owners” of the Velux integration.
It is really unfortunate that your shutter was damaged while using the integration. That said, I don’t think it is the integration’s responsibility to add the safeguards you’re asking for. As far as I know (I don’t own a window/shutter combination with that issue), you can reach the same “result” (a damaged shutter) simply by using the original remote. So, in my opinion, this is a problem with the Velux hardware, not the integration.
As Sir_Goodenough mentioned, HA allows you to improve the Velux system by using the window position to prevent shutter movement when the window is open. Pyvlx (the library used in HA) recently added support for setting open/close limits for cover devices. Once this is integrated into HA, you will be able to completely prevent forbidden movements, even when using the Velux remote. However, I still don’t think such automatic limitations should be built into HA itself; rather, HA can (and does) provide ways to improve upon the original Velux hardware.
One thing you mentioned that I’d be curious to learn more about: you said you need a reliable stop command. Does this mean that issuing a stop command to the shutter does not work if the shutter is already moving? If so, please open an issue in the core repo and provide debug logs for such a situation. This is something that should work, or at least, I haven’t heard of a device where it doesn’t.
The next release of HA will allow you set open/close limits on all Velux covers (see Add number entities for velux opening device limitations by wollew · Pull Request #174388 · home-assistant/core · GitHub). This will allow you to create an automation that essentially sets a limit on how far you can close your shutter when the window is open (and remove the limitation when the window is closed). This will limit will be “global”, meaning it also works for commands sent from a remote, not only HA commands.
