Controls a Vent-Axia Pax (Svara/Calima, or compatible) extractor boost switch from dew-point logic. When there is risk of mould for 30 minutes (configurable), boost turns on; when it is no longer warranted for the same delay, boost turns off.
Requires Home Assistant 2023.4 or later. Room sensors and boost switch assume the ha-pax_ble integration (BLE or local API).
Vent warranted formula
Ventilation is warranted when both are true:
- Mould floor: room dew point ≥ mould floor (default 16 °C). Below this, extracting heated indoor air usually costs more than the mould risk justifies in winter.
- Outdoor delta: room dew point > outdoor dew point + delta (default 1.0 °C). Outdoor air is materially drier, so extraction removes humidity instead of adding it.
Dew point is calculated inside the blueprint (Magnus formula from temperature + humidity), or you can point it at existing dew point sensors.
What it does
- Warranted for N minutes: turn boost on if it is off.
- Not warranted for N minutes: turn boost off if it is on.
- Single automation; thresholds and dew point source are blueprint inputs.
Required entities (calculate mode, default)
| Role | Example | How to get it |
| Room temperature | sensor.top_bathroom_extractor_temperature |
Pax integration (see link above) |
| Room humidity | sensor.top_bathroom_extractor_humidity |
Pax integration |
| Outdoor temperature | sensor.met_no_outdoor_temperature |
Weather integration (Met.no, Met Office, etc.) |
| Outdoor humidity | sensor.met_no_outdoor_humidity |
Weather integration |
| Boost switch | switch.top_bathroom_extractor_boostmode |
Pax integration (boost mode, not fan power) |
Entity IDs vary by integration and room name; the examples above are from one install.
Sensors mode (optional)
Set Dew point source to Use dew point sensors if you already maintain room and outdoor dew point entities.
Caveats
- May turn off boost you enabled manually in the Pax app when warranted stays off for the full delay.
- If Pax temp/RH sensors are unavailable, boost will not change until readings return.
Blueprint
blueprint:
name: Pax extractor boost when dew-point ventilation warranted
description: >
Turn a Vent-Axia Pax (Svara/Calima, or compatible) extractor **boost mode** switch
**on** or **off** when dew-point ventilation is warranted, with a stability delay
so boost does not flap.
**Vent warranted** when both are true:
1. Room dew point is at or above the mould floor (default 16 °C) - winter heat-loss
guard so you do not extract expensive heated air unless humidity is mould-relevant.
2. Room dew point is more than *outdoor dew point + delta* (default 1.0 °C) - outdoor
**Dew point source**
- *Calculate* (default): Magnus formula from room and outdoor temperature + humidity.
- *Sensors*: use existing room and outdoor dew point `sensor.*` entities.
**Behaviour**
- Warranted **on** for *N* minutes → `switch.turn_on` (only if boost is off).
- Warranted **off** for *N* minutes → `switch.turn_off` (only if boost is on).
**Caveat:** may turn off boost you enabled manually in the Pax app when warranted
author: Tom
domain: automation
homeassistant:
min_version: 2023.4.0
input:
dew_point_source:
name: Dew point source
description: Calculate from temperature and humidity, or use existing dew point sensors.
default: calculate
selector:
select:
options:
- label: Calculate from temperature and humidity
value: calculate
- label: Use dew point sensors
value: sensors
room_temperature:
name: Room temperature
description: Pax fan or room temperature sensor (calculate mode only).
selector:
entity:
filter:
- domain: sensor
device_class: temperature
room_humidity:
description: Pax fan or room humidity sensor (calculate mode only).
selector:
entity:
filter:
- domain: sensor
device_class: humidity
outdoor_temperature:
name: Outdoor temperature
description: Weather integration outdoor temperature (calculate mode only).
selector:
entity:
filter:
- domain: sensor
outdoor_humidity:
description: Weather integration outdoor humidity (calculate mode only).
selector:
entity:
filter:
- domain: sensor
room_dew_point:
name: Room dew point
description: Room dew point sensor (sensors mode only).
selector:
entity:
filter:
- domain: sensor
outdoor_dew_point:
name: Outdoor dew point
description: Outdoor dew point sensor (sensors mode only).
selector:
entity:
filter:
- domain: sensor
mould_floor_c:
name: Mould floor (°C dew point)
description: Minimum room dew point before boost is considered (UK mould band ~16–18 °C).
default: 16
selector:
number:
min: 10
max: 25
step: 0.5
unit_of_measurement: "°C"
mode: box
outdoor_delta_c:
name: Outdoor delta (°C)
description: Room dew point must exceed outdoor dew point by at least this much.
default: 1.0
selector:
number:
min: 0
max: 5
step: 0.1
mode: box
boost_switch:
name: Extractor boost switch
description: Switch entity for Pax **boost mode** (not the fan power relay).
selector:
entity:
filter:
- domain: switch
stable_minutes:
description: >
Minutes vent-warranted must stay **on** or **off** before boost changes.
Filters brief spikes (default 30).
default: 30
selector:
number:
min: 1
max: 120
unit_of_measurement: min
mode: box
mode: single
triggers:
- trigger: template
value_template: >
{% if '!input dew_point_source' == 'sensors' %}
{% set room_dp = states('!input room_dew_point') | float(none) %}
{% set outdoor_dp = states('!input outdoor_dew_point') | float(none) %}
{% else %}
{% set rh_r = states('!input room_humidity') | float(none) %}
{% set t_r = states('!input room_temperature') | float(none) %}
{% set room_dp = none if rh_r is none or t_r is none or rh_r <= 0
else (243.5 * (((rh_r / 100) | log) + (17.67 * t_r) / (243.5 + t_r))
/ (17.67 - ((rh_r / 100) | log) - (17.67 * t_r) / (243.5 + t_r))) | round(1) %}
{% set rh_o = states('!input outdoor_humidity') | float(none) %}
{% set t_o = states('!input outdoor_temperature') | float(none) %}
{% set outdoor_dp = none if rh_o is none or t_o is none or rh_o <= 0
else (243.5 * (((rh_o / 100) | log) + (17.67 * t_o) / (243.5 + t_o))
/ (17.67 - ((rh_o / 100) | log) - (17.67 * t_o) / (243.5 + t_o))) | round(1) %}
{% endif %}
{{ room_dp is not none and outdoor_dp is not none
and room_dp >= !input mould_floor_c
and room_dp > outdoor_dp + !input outdoor_delta_c }}
for:
minutes: !input stable_minutes
- trigger: template
value_template: >
{% else %}
{% endif %}
{% set warranted = room_dp is not none and outdoor_dp is not none
and room_dp > outdoor_dp + !input outdoor_delta_c %}
{{ room_dp is not none and outdoor_dp is not none and not warranted }}
for:
actions:
- choose:
- conditions:
- condition: trigger
- condition: state
entity_id: !input boost_switch
state: "off"
sequence:
- action: switch.turn_on
- conditions:
- condition: state
state: "on"
sequence:
- action: switch.turn_off
