Hi
i am trying to make a ventilation automation based on VOC and Humidity with a bypass button.
i almost got it working
1 fan on the roof.
I got 3 humidity sensors that starts the fan if one of them goes over 70% and turns off the fan again is all are under 50%
I got 2 VOC sensors that turn on the fan if the value is over 200 and off again if both are under 100. all 5 sensors in same automation
i only have problems getting my sonoff button SNZB-01 to act as a bypass button for when i want to start a fire in the fireplace.
reason for bypass that i get a backdraft through the chimney and fills the whole house with smoke if the fan is running.
promlem is that SNZB-01 it is not a sensor and it only triggers an event and i cant seem to get it right
alias: Fan Control Based on Humidity & Air Quality
description: ""
triggers:
- entity_id:
- sensor.bad_climate_01_humidity
- sensor.bed_climate_01_humidity
- sensor.kit_climate_01_humidity
above: 60
trigger: numeric_state
- entity_id:
- sensor.bed_climate_01_voc
- sensor.hal_up_climate_01_voc
above: 200
- value_template: |-
states('sensor.bad_climate_01_humidity') | float(0) < 50 and
states('sensor.bed_climate_01_humidity') | float(0) < 50 and
states('sensor.kit_climate_01_humidity') | float(0) < 50 and
states('sensor.bed_climate_01_voc') | float(0) < 100 and
states('sensor.hal_up_climate_01_voc') | float(0) < 100
trigger: template
- trigger: mqtt
topic: zigbee2mqtt/KAMIN
payload: action:"single"
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
sequence:
- target:
entity_id: switch.pro2pm_h_01_switch_0
action: switch.turn_on
data: {}
- conditions:
sequence:
- target:
data: {}
- conditions:
sequence:
- target:
action: switch.turn_off
data: {}
- conditions:
id:
- bypass
sequence:
- target:
data: {}
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- action: switch.turn_on
metadata: {}
data: {}
mode: restart
any ideas where i f… up ?
Greets
Thomas
