For a while I’ve been using home assistant together with my Vera edge z-wave controller and the vera component. It work like a treat, but now that I added a lot of devices last weekend (light switches and motion sensors), triggers from the vera are often not picked up.
In the hass log files, I see a lot of errors like these:
2018-01-08 20:01:56 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.bedlamp_schakela_9 fails
File "/usr/local/lib/python3.4/dist-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.4/dist-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/local/lib/python3.4/dist-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 357, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/usr/local/lib/python3.4/dist-packages/urllib3/connection.py", line 166, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.4/dist-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x6ac00f90>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.4/dist-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.4/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.4/dist-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.2.5', port=3480): Max retries exceeded with url: /data_request?output_format=json&id=variableget&Variable=LastSceneID&serviceId=urn%3Amicasaverde-com%3AserviceId%3ASceneController1&DeviceNum=9 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6ac00f90>: Failed to establish a new connection: [Errno 111] Connection refused',))
It seems like the vera thinks hass is polling it too often and is refusing connections. Is there anything I could do about this?
