Vera NorthQ watt calculator: values not updating
I have a NorthQ power meter device connected to Vera that reads my power meter. To get the current watt usage I have installed the NorthQ watt calculator plugin on my Vera. The plugin calculates the watt usage based on two readings of the power meter. It works in Vera but in hass.io the watt value only updates when reloading.
What makes hass.io update values from Vera? Do I have to modify the NorthQ watt calculator plugin to get hass.io to update the value on change? Or is there some settings in hass.io to get it to read the value in set intervals?
Have the same problem and tried to troubleshoot. It seems like (for me at least) the actual Vera plugin is not working - I have had the same value for quite some while now.
Numbers reported from NorthQ seems to work correct…
