Verizon FiOS Router Integration for Home Assistant
https://github.com/skircr115/ha-verizonFiOS
hacs_badge GitHub Release License Maintenance
A comprehensive Home Assistant integration for Verizon FiOS CR1000A and CE1000A routers.
Features
:dart: 100+ Sensors!
This integration provides extensive monitoring of your Verizon FiOS network:
Sensor Count:
  • Router only: ~70 sensors
  • Router + 1 extender: ~115 sensors :white_check_mark:
  • Router + 2 extenders: ~160 sensors
Coverage:
  • Router Performance: CPU, memory, temperature, uptime
  • Network Quality: Signal strength, SNR, retry rates, error rates per band
  • Device Tracking: Total, active, inactive, by type, by vendor, by OS
  • WiFi Analytics: Per-band device counts (main/IoT/guest), WiFi standards (4/5/6/6E)
  • Mesh Network: Full extender monitoring with all the same metrics
  • All SSIDs: Main, Guest, IoT, IPTV, Backhaul networks
:bar_chart: Sensor Categories
Core Router Metrics
  • CPU usage (total, user, system, idle)
  • Memory (used, free, total, percentage)
  • Temperature monitoring
  • Uptime tracking
Network Breakdown
  • Devices per band: 2.4GHz, 5GHz, 6GHz
  • Sub-network tracking: Main, IoT, Guest, IPTV, Backhaul
  • Ethernet/wired connections
  • WiFi standard distribution (WiFi 4/5/6/6E)
Network Quality (per band)
  • Average signal strength
  • Min/max signal strength
  • Average SNR (signal-to-noise ratio)
  • Average link rates
  • Packet retry counts
  • Error counts
Device Intelligence (Attribute-Based)
  • By Type: Single sensor with device type breakdown in attributes (phones, tablets, computers, IoT, cameras, TVs, etc.)
  • By Vendor: Single sensor with vendor breakdown in attributes (Apple, Samsung, Google, and more)
  • By OS: Single sensor with OS breakdown in attributes (Android, iOS, Windows, macOS, Linux, embedded)
Access device details via attributes for cleaner entity management!
Mesh Extenders (per extender)
  • All router metrics (CPU, memory, temperature, uptime)
  • Connection details (signal, type, link rate)
  • Per-band device counts
  • Update status
Direct HACS Installation Link:
