Hi, I’m really lost. I was on my Home Assistant web panel and saw a notification for an update. I clicked on it and tried updating and then it said that my system was unhealthy. I thought nothing of it until I reloaded the page and it was no longer working. I checked supervisor logs and saw something that caught my eye:
ERROR (MainThread) [supervisor.dbus.network] Version '1.10.6' of NetworkManager is not supported!
I checked my supervisor version and it was updated to 2022.5.2 but my core was still 2021.4.6.
Now, I wanted to avoid further conflict so I tried downgrading my supervisor back to 2021.4.3 but it doesn’t let me saying:
ha su update --version=2022.4.3
Error: No supervisor update available - 2022.05.2
22-05-17 09:34:37 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-05-17 09:34:37 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-05-17 09:34:37 WARNING (MainThread) [supervisor.dbus.manager] Can't load dbus interface io.hass.os: The name io.hass.os was not provided by any .service files
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-05-17 09:34:37 ERROR (MainThread) [supervisor.dbus.network] Version '1.10.6' of NetworkManager is not supported!
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-05-17 09:34:37 WARNING (MainThread) [supervisor.dbus.manager] Can't load dbus interface de.pengutronix.rauc: The name de.pengutronix.rauc was not provided by any .service files
22-05-17 09:34:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-05-17 09:34:37 INFO (MainThread) [supervisor.host.info] Updating local host information
22-05-17 09:34:37 INFO (MainThread) [supervisor.host.services] Updating service information
22-05-17 09:34:37 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-05-17 09:34:37 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-05-17 09:34:37 INFO (MainThread) [supervisor.jobs] 'NetworkManager.load' blocked from execution, host Network Manager not available
22-05-17 09:34:37 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-05-17 09:34:37 WARNING (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
22-05-17 09:34:37 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.05.0
22-05-17 09:34:37 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-05-17 09:34:37 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-05-17 09:34:37 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.05.0
22-05-17 09:34:37 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-05-17 09:34:37 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-05-17 09:34:37 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-05-17 09:34:38 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2021.4.6
22-05-17 09:34:38 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
22-05-17 09:34:38 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found
22-05-17 09:34:38 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-05-17 09:34:38 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-05-17 09:34:40 INFO (MainThread) [supervisor.store] Loading add-ons from store: 62 all - 62 new - 0 remove
22-05-17 09:34:40 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-05-17 09:34:40 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-05-17 09:34:40 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-05-17 09:34:40 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-05-17 09:34:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-05-17 09:34:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-05-17 09:34:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-05-17 09:34:40 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: Ubuntu 18.04.6 LTS (more-info: https://www.home-assistant.io/more-info/unsupported/os)
22-05-17 09:34:40 WARNING (MainThread) [supervisor.resolution.evaluations.base] NetworkManager is not correctly configured (more-info: https://www.home-assistant.io/more-info/unsupported/network_manager)
22-05-17 09:34:40 WARNING (MainThread) [supervisor.resolution.evaluations.base] OS-Agent is not correctly working (more-info: https://www.home-assistant.io/more-info/unsupported/os_agent)
22-05-17 09:34:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-05-17 09:34:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-05-17 09:34:40 INFO (MainThread) [__main__] Running Supervisor
22-05-17 09:34:40 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
22-05-17 09:34:40 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
22-05-17 09:34:40 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-05-17 09:34:40 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-05-17 09:34:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-05-17 09:34:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-05-17 09:34:40 INFO (MainThread) [supervisor.host.info] Updating local host information
You’re trying to do a supervised install in an unsupported OS. Ubuntu has a lot of things different from debian, network manager is one. Would recommend trying a supported installation method
I understand but I’ve been using Home Assistant for quite some time now and it’s been working fine. I don’t have the luxury switching my OS now so I was hoping you guys could help me out here.
Sorry, no idea, that’s what unsupported means. HA interacts heavily with the underlying hardware and host OS. Since it knows that is supposed to be either stock Debian or HAOS it freely adds dependencies on features it knows should be there in those two OS’s. Ubuntu isn’t either of those and so may or may not have something HA now depends on in any given release. Seems like you hit one of those.
I could have written this post a year ago. I was also running Home Assistant on Ubuntu and kept running into this error.
The workarounds only worked for a while, but it was getting to the point that I couldn’t make any changes or updates to my Home Assistant. I also did not want to change my OS, so I just bought an Intel NUC i3, added RAM and SSD, then flashed the Generic X86 image of Home Assistant OS. Wow. compared to a Raspberry Pi, the NUC was supercharged. Highly recommended. I bought my NUC new, but you can find an i3 or even an i5 on eBay for less than $100.
If networkmanager is not supported, then you can use other methods to manager your network connections.
Ubuntu has all the old ways still.
The hard part is to untangle networkmanager from all the settings and then set up the network with whatever other method you choose (better choose one that is supported ;))
