Also where is the time is x for? Also with that set to 1 second the tester gives the status ‘not passed’. I assume I can leave the timer empty?
Does the timer work like this: if set the 00:00:01 the 1 second after winter season changes to spring, then do your thing? Or does it work like this: under the condition that season is spring for at le4ast 1 second, do your thing?
hi thjanks for the quick reply entity/attribute/State, its all so confuzing.
But it pased when leaving the Attriburte empty (UX improval: show only the fields that are for this ‘Entity’)
For example, if you set it to 10 seconds, the sensor’s value must be Spring for at least 10 seconds in order for the condition to be fulfilled.
It’s important to understand that the condition doesn’t wait for the sensor’s value. At the moment the condition checks the value it must already be Spring for at least 10 seconds.
@123 Thanks. And in your example: what happen if the condition time =10 seconds and it checks at 12 seconds. Then it also a ‘yes’? As I understand it, the timere is not a tricker but a condition for a tricker?
when PV to network delevery to grid is above certain value and next hour also, then set nodon switch to ‘on’ for the PV smartgrid on my heat pump to make the boiler water 10 degrees celcius higher. ( I now set the start time at 12:00 and want to start 1 hour (3600 seconds) before highest forecast solar production
under certian conditions per season, slike sporing like currentpower is -1500 kW(delivery to grid) and forecast next hour is > 0,6 kWh
And another action to other way around…
the season=spring is now working, so I test further if the other restrictiions are not to strict.
Don’t post screenshots. Most here won’t read them.
Edit the automation in YAML, click on “copy to clipboard”, then paste that into the forum using code tags.
Oké, Here it is. I simplified the tricker to just tricker on time. I tested spring condition witch is green, Oke. But still the action is not working.
Running the complete automation, it’s setting the device to on, do that’s working.
Any other errors a made?
The conditions are OR and not AND, i assume?
alias: v.02 Als PV overschot > verhoog buffer
description: >-
Als PV vermogen meer dan waarde season voor huidige opwek en komend uur
voorspelling, zet extra verwarming Wolf zoals ingesteld in Wolf smartset
triggers:
- trigger: time
at: "13:50:00"
conditions:
- alias: If conbditiona match spring
condition: and
conditions:
- condition: state
entity_id: sensor.season
state: spring
- condition: numeric_state
entity_id: sensor.energy_next_hour
above: 0.6
entity_id: sensor.p1_meter_vermogen
below: -1.5
- alias: If conbditiona match summer
condition: and
conditions:
above: 1
below: -3
- condition: state
state: Summer
- alias: If conbditiona match Autumn
condition: and
conditions:
above: 0.6
below: -1.5
- condition: state
state: Autumn
- alias: If conbditiona match Winter
condition: and
conditions:
above: 0.6
below: -1.5
- condition: state
state: Winter
actions:
- type: turn_on
device_id: 7a739ad799f54b2161410c7329af5c12
entity_id: 35b896d51e92b58b34568ea90ab9d31d
domain: light
flash: long
- action: notify.mobile_app_iphone_12_keesjan
metadata: {}
message: Wp warm water PV verhoging aan
title: "HA boodschap "
mode: single
You assume incorrectly. Conditions are AND by default, unless you explicitly set them to OR.
What you currently have here will never cause your automation to perform the actions, because your conditions are checking whether the season is spring AND summer AND autumn AND winter.
You will need to use Choose in order to determine what numeric states it should validate, depending on the season.
You didn’t run the complete automation - you ran the action part by itself. That skips the entire trigger & condition section and only runs the action part - that’s why it worked.
