Very simple script, help
Trying to do my first script (two events one after the other)
I have two switch, one is sending a command to turn on an electric switch, the other is a IR commands to turn on a projector (connected electrically to the electric switch).
I simply need to turn on the electric switch, wait maybe 1 second and then send the IR signal to power on.
How to do this simple sequence?
The command should be inside a card as a single switch
switch.p13_projector
switch.projector_living:
Maybe anything like this?
If you manual switch on swtich.p13_projector, than power on the projector.
automation:
    platform: state
    entity_id: switch.p13_projector
    state: 'on'
    service: script.turn_on
    entity_id: script.projector_poweron
script:
  projector_poweron:
    sequence:
        - delay:
          seconds: 1
        - service: switch.turn_on
            entity_id: switch.projector_living
Thanks I wil try.
Please note, my switch are of this format
projector_living:
      command_on: "curl -X GET http://192.168.1.50:9876/send?deviceMac\u0xxxxxxxxxxxx"
      command_off: "curl -X GET http://192.168.1.50:9876/send?deviceMac\xxxxxxxxxxxxxx"
if the entity_id for the switch is working in HA , the format is not important
