I have a simple graphical menu set up with esphome on a Firebeetle ESP32E. I am using a Waveshare 2.4in LCD screen.
It’s connected to a rotary encoder which controls the menu
It is all working perfectly, but when the list is long (say above 20 items) moving the menu between items is quite slow.
It’s quicker with a shorter list, but still pretty slow.
Any ideas on why this might be? I have tried adding two “move up” commands one after the other in the script and there’s a little delay between even those so I don’t think it’s just the rotary encoder that’s being slow to respond - it seems it’s the graphical menu that’s taking time to move between elements.
Here’s the main code - I haven’t included the graphical menu as it’s quite long
esphome:
esp32:
board: firebeetle32
framework:
type: arduino
# Enable logging
logger:
logs:
component: ERROR
# Enable Home Assistant API
api:
password:
ota:
- platform: esphome
password:
wifi:
ssid: ""
password: ""
ap:
ssid: "
manual_ip:
# Set this to the IP of the ESP
static_ip:
# Set this to the IP adress of the router. Often ends with .1
gateway:
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
captive_portal:
- platform: rotary_encoder
pin_a:
number: GPIO16 # Connect CLK to D1
mode:
input: true
pullup: true
pin_b:
number: GPIO17 # Connect DT to D2
mode:
input: true
pullup: true
resolution: 1
filters:
debounce: 10ms
on_clockwise:
- logger.log: "Moved up" # Log message on button press
- display_menu.up: my_graphical_display_menu
on_anticlockwise:
- display_menu.down: my_graphical_display_menu
- logger.log: "Moved down" # Log message on button press
# Example minimal configuration entrydisplay:
spi:
clk_pin: GPIO18 # Clock pin (often labeled as SCK)
mosi_pin: GPIO23 # Master Out Slave In (often labeled as MOSI or SDA)
miso_pin: GPIO19 # Master In Slave Out (often labeled as MISO, optional for this display)
# Configure the display
display:
- platform: ili9xxx
model: ili9341
cs_pin: GPIO14
dc_pin: GPIO25
reset_pin: GPIO26
invert_colors: false
rotation: 90
pages:
- id: graph_page
lambda: |-
it.print(0, 0, id(my_font), "My menu is not currently active");
it.print(0, 20, id(my_font), id(my_global_string).c_str());
font:
- file: "gfonts://Open+Sans"
binary_sensor:
- platform: gpio
name: "Rotary Encoder Button"
pin:
number: GPIO4 # Replace with the pin connected to the button
mode:
input: true
pullup: true # Use an internal pull-up resistor
inverted: true # Ensure it works correctly with active-low buttons
filters:
- delayed_on: 30ms
- delayed_off: 30ms
on_press:
- logger.log: "Rotary Encoder Button Pressed!" # Log message on button press
- if:
condition:
display_menu.is_active: my_graphical_display_menu
then:
- display_menu.enter: my_graphical_display_menu
else:
- display_menu.show: my_graphical_display_menu
mqtt:
broker: "
# Include the graphical display menu from a separate file
graphical_display_menu: !include graphical_display_menu.yaml
