I have a Viessman hybrid heating gas and heat pump. However, I can only select gas or heat pump as the heating type in the configuration. So I can not display data from the gas and heat pump sensors at the same time.
Same here, would be great if there will be any workaround or upgrade for this integration
I’m in the same boat, it only shows the gas, the heatpump is not visible
