Hi everyone,
I would like to introduce Victron Charge Control, a custom Home Assistant integration for Victron ESS systems.
The integration automatically controls battery charging and discharging based on EPEX Spot hourly electricity prices. The goal is simple: charge the battery during cheap hours, discharge or export during expensive hours, and keep everything adjustable directly from the Home Assistant UI.
Repository:
What It Does
Auto mode calculates a daily schedule from EPEX Spot prices.
Manual mode lets you choose specific hours for charging, discharging, blocking, or idling.
Force charge / force discharge modes are available for immediate control.
SOC limits prevent charging above or discharging below configured battery levels.
Grid setpoint limits help keep the Victron ESS setpoint within safe bounds.
Grid feed-in limiting can reduce feed-in when electricity prices are low or negative.
All settings are available in the UI, so no YAML editing is needed after setup.
Why I Built It
I wanted a more convenient way to use dynamic electricity pricing with a Victron ESS setup. Existing Victron and EPEX integrations provide the data and writable entities, but I wanted a dedicated control layer that combines them into an hour-by-hour charging plan.
This integration is meant for people who want to:
Charge their battery during the cheapest spot price hours.
Discharge or export during the most expensive hours.
Avoid charging or discharging during specific blocked hours.
Keep a configurable SOC reserve.
Adjust the strategy directly from Home Assistant.
Requirements
The integration currently expects these pieces to already be available in Home Assistant:
Home Assistant 2026.2 or newer
HACS
A writable Victron ESS grid setpoint entity, for example from Victron GX modbusTCP
Victron battery SOC and power sensors, for example from Victron Venus MQTT
EPEX Spot hourly price data, for example from the EPEX Spot integration
A writable max grid feed-in entity if you want to use feed-in limiting
During setup, the config flow asks for six entities:
Battery SOC sensor
Grid setpoint entity
Grid power sensor
Battery power sensor
EPEX Spot price sensor
Max grid feed-in entity
Created Controls
The integration creates a device with runtime controls such as:
Control mode:
off,auto,manual,force_charge,force_discharge -
Charge and discharge enable switches
Minimum and maximum SOC
Charge and discharge power
Idle, minimum, and maximum grid setpoints
Number of cheapest hours to charge
Number of most expensive hours to discharge
Charge and discharge price thresholds
Blocked charging and discharging hours
Grid feed-in price threshold and feed-in limits
A button to recalculate the schedule
Sensors showing the desired action, target setpoint, charge hours, discharge hours, and full charge plan
Current Status
This is an initial release, currently version 1.0.0. It works as a local polling integration and is installable through HACS as a custom repository.
I would be very happy to get feedback from other Victron ESS users, especially around different entity setups, EPEX Spot configurations, and control strategies. Issues and feature requests are welcome on GitHub:
Thanks, and I hope this is useful to others running Victron with dynamic electricity pricing.
