New to the forums as well as home assistant. It’s absolutely fantastic and i’m loving it! So thanks everyone in the community.
I found this GitHub - Fabian-Schmidt/esphome-victron_ble: Use official Victron BLE endpoint for fetching data from Victron devices via Bluetooth LE via ESPHome.
and had pretty good success. Except for my Victron BMV-712 Smart
I’m trying to get my “batteries” into Home assistant with no luck.
The Setup:
3 Victron MPPT solar charge controllers. (StBd Solar, Port Solar, Arch Solar)
1 BMV-712 Smart (essentially the “Victron Smart Shunt”)
Using EPSHome/ESP32.
Under the Energy tap i’m able to add the charge controllers under the “solar” section. However I can’t seem to add the battery, it’s not really showing what i need? I think? Like what entities should i be using or am i wrong in thinking I can integrate the BMV as the battery?
Here is the code i’m using:
# All Sensors (Merged)
# ArchSolar Sensors
- platform: victron_ble
victron_ble_id: ArchSolar
name: "Battery Voltage (ArchSolar)"
type: BATTERY_VOLTAGE
name: "Battery Current (ArchSolar)"
type: BATTERY_CURRENT
name: "Yield Today (ArchSolar)"
type: YIELD_TODAY
name: "PV Power (ArchSolar)"
type: PV_POWER
name: "Load Current (ArchSolar)"
type: LOAD_CURRENT
- platform: integration
name: "Solar Energy Produced (ArchSolar)"
sensor: pv_power_arch
unit_of_measurement: "Wh"
time_unit: h
accuracy_decimals: 2
state_class: total_increasing
device_class: energy
# PortSolar Sensors
victron_ble_id: PortSolar
name: "Battery Voltage (PortSolar)"
name: "Battery Current (PortSolar)"
name: "Yield Today (PortSolar)"
type: YIELD_TODAY
name: "PV Power (PortSolar)"
type: PV_POWER
name: "Load Current (PortSolar)"
type: LOAD_CURRENT
name: "Solar Energy Produced (PortSolar)"
sensor: pv_power_port
time_unit: h
# StBdSolar Sensors
victron_ble_id: StBdSolar
name: "Battery Voltage (StBdSolar)"
name: "Battery Current (StBdSolar)"
name: "Yield Today (StBdSolar)"
type: YIELD_TODAY
name: "PV Power (StBdSolar)"
type: PV_POWER
name: "Load Current (StBdSolar)"
type: LOAD_CURRENT
name: "Solar Energy Produced (StBdSolar)"
sensor: pv_power_stbd
time_unit: h
# VictronBMV
victron_ble_id: VictronBMV
name: "Time remaining"
type: TIME_TO_GO
name: "Starter Battery Voltage"
# AUX_VOLTAGE or MID_VOLTAGE or TEMPERATURE.
# Depending on configuration of SmartShunt.
type: AUX_VOLTAGE
type: CONSUMED_AH
name: "State of charge"
type: STATE_OF_CHARGE
# All Binary Sensors (Merged)
binary_sensor:
# Arch Solar
name: "MPPT is in Fault state (ArchSolar)"
type: DEVICE_STATE_FAULT
name: "MPPT has Error (ArchSolar)"
type: CHARGER_ERROR
name: "MPPT in FLOAT (ArchSolar)"
type: DEVICE_STATE_FLOAT
# Port Solar
name: "MPPT is in Fault state (PortSolar)"
name: "MPPT has Error (PortSolar)"
type: CHARGER_ERROR
name: "MPPT in FLOAT (PortSolar)"
# StBd Solar
name: "MPPT is in Fault state (StBdSolar)"
name: "MPPT has Error (StBdSolar)"
type: CHARGER_ERROR
name: "MPPT in FLOAT (StBdSolar)"
#Victron BMV
name: "Battery has Alarm"
type: ALARM
# All Text Sensors (Merged)
text_sensor:
# Arch Solar
name: "MPPT state (ArchSolar)"
type: DEVICE_STATE
name: "MPPT Error reason (ArchSolar)"
type: CHARGER_ERROR
# Port Solar
name: "MPPT state (PortSolar)"
type: DEVICE_STATE
name: "MPPT Error reason (PortSolar)"
type: CHARGER_ERROR
# StBd Solar
name: "MPPT state (StBdSolar)"
type: DEVICE_STATE
name: "MPPT Error reason (StBdSolar)"
type: CHARGER_ERROR
# Victron BMV
name: "Battery Alarm reason"
type: ALARM_REASON
