Can you please explain a bit more about how you got this to work? I see the same URLs when I’ve tried to reverse engineer mine but can’t get it working. Using the ucarehome app my door unlock normally requires a passcode, I have tried with this in the URL but still not working.
Do you do a POST or a GET request and do you include an authentication header or bearer token in your URL request?
It’s a POST and the user and password are on the query string, not on the auth header .
The open door URL don’t need auth !!! Scary …
Did you see the bell ring trigger on the app to the uCareHome cloud ? I want this command to try use HA but didn’t had time to look for it . My idea is to “hack” the DNS and receive the trigger on a local web server and send it to HA . Idk the host and url and auth mechanism yet .
Thanks, I’ll have another go with the door unlock. Do you have to activate the stream first with this command http ://IP/cgi-bin/hi3510/doorConnect.cgi?&-door=0 or should it just work?
Nope, I haven’t seen the bell ring trigger. I looked at this last year but now have a bit more time and so am keen to try and get this working again. I have a spare raspberry pi so if not I thought I could install android on it and have it send an MQTT command when the notification pops up.
Yes , you need to activate it every 10 min approx … a wget on cron do the job … the lcd screen stays on during this … it’s like the activate function using the app .
I use the stream on zoneminder but only when it’s on … motion recording . During the off time the stream stays on but always black .
Nice . If you can get some info about the trigger please show it . Thanks
Hello, I’m new to the community and I also have this doorbell from tmezon V103W, I wish to control it without ucarehome app… trying with postman but can’t do anything, someone can help me?
I have a diferent version, stream not work, port rtsp 554 is closed when I exec nmap 192.168.1.x only port 80 and 7778 is open. I had a previous version with port 554 open.
I try stream in rtsp://{{IP}}:80/livestream/11?action=play&media=video_audio_data but I couldn’t get it work.
Im trying create motion sensor in HA throw email alert but today not work:
Other tip, you can explore sd card in url with your user and password:
I’ve found an interesting discovery as I was messing with this on a PC running Windows 7 with the odd plugin (a provided .zip file containing a .exe installer for an IE plugin) and Wireshark running in the background:
By the way, I have the 7" version, but I believe the firmware is 1:1. These doorbell monitors use a HiSilicon Hi3510 SOC which not only is a huge security risk (I can reboot and do many things to it without even logging in), but it also has a weird video output path (not your typical HTTP://[IP]:554/11), though sadly accessing this livestream feed only gives me a HTTP 400 error.
Always blocked with this intercom, impossible to recover the video stream to put on HA… It bothers me to have to buy another intercom… has anyone found a solution?
