Viessmann ViCare Thermostatic Radiator Valve
Thank you, that you implemented a first step to support the ViCare TRV.
However, only the temperature is available, not full support as thermostat. Is that a limitation of the Viessmann API or a limitation in the integration?
I personally would appreciate support full for the TRV, so that they can also be controlled via HA.
