Hello, I have added a USB meshcore device to my home assistant and was wondering how I could get an entity with all messages received on a channel. Specifically public. I sent a few test messages and it doesn’t show anything at all under channels and public. Says zero. I see a number of messages from weather and stuff but I don’t see the messages. How would I make an entity for each channel to read messages, use messages as triggers, and send messages?
Now I’m just looking to read messages stored in an entities history when I am not physically at a location with good service.
Despite slapping 80+ nodes (45 meshtastic and 35 meshcore) all around this mountain town it’s hard to tell when a message sent will show up on public at home and vise versa.
In order to not have to 3d print and assemble more nodes than necessary I wanted to be able to use this as an easy tool to see if dm’s and/or public messages can reach a particular place. Then stick a repeater somewhere and try again basically.
Rinse and repeat.
I just can’t seem to see the public channel like I did with meshtastic. Any help would be fantastic.
Edit if it matters, it’s a heltec v3 running non custom USB companion firmware with a 8000mah battery and duck antenna case.
Odroid n2+ supervised
