Hi everybody,
when I run esphome <file.yaml> run --upload-port=<ip>
, it will upload my new code and then display a lot in the terminal. When I CTRL+C
, this log stops, of course.
Is it possible to view this log later on? I have tried different combinations of the logs command, for example esphome logs --host-port=<ip>
, but this only throws an error.
It’d be quite nice to view the logs instead of waiting for the integration in Home Assistant to reload, especially when testing things. I am currently trying to set up an SR-HC04 distance sensors. It keeps showing different values in Home Assistant (without being moved). I thought this might be related to my USB hub, so I connected it to an outlet via a USB adapter. It works, but there are still different values showing up. Now that it is connected to an outlet, I cannot even try viewing the logs via something like /dev/ttyUSB0
or similar.
Thank you for your help
