I have two different to-do lists. I am trying to view both of them at the same time, in different windows. But when I change which to-do list that I’m looking at in one window, the other window also changes, a second or so later, so that I’m viewing the same to-do list in both windows.
I cannot figure out how to independently look at two different to-do lists in two different windows simultaneously. The URL used doesn’t change but the list being viewed does.
For example, I have window 1 with …:8123/todo?entity_id=todo.hvac_profiles
and window 2 with :8123/todo?entity_id=todo.hvac_zones. Yet both windows are showing the profiles to-do list. If I change the to-do list being viewed in one of the windows, the other window follows suit shortly after (without altering any URLs).
Just tried same with calendars and the similar behavior (but without the URLs being different here its just …:8123/calendar) - change what calendar is being viewed in one window (here via checkboxes) and other windows open to calendar also change. While this one doesn’t seem like a really useful feature, at least the URL parameters aren’t being wholly ignored.
