I have Home Assistant Core running under Ubuntu and while everything works great, I was looking for a way to see the current Zigbee channel being used by the hub.
Anyone know how I can achieve that?
bellows -d /dev/ttyUSB0 info
That should output your channel info.
Sorry to revive this thread but when I run the code you suggested I get:
bellows: command not found
I am running Home Assistant under venv on Ubuntu using the same stick. Any ideas?
