Vintage Pioneer Stereo Amp Ir and ProntoCode to yaml
VintagePioneerIR is an open-source ESPHome solution designed to bring vintage Pioneer amplifiers into the smart home era.
Just connect an ESP32 with an IR LED, and control your classic amp via Home Assistant—no original remote needed.
Out-of-the-box, it replaces lost or broken remotes, and supports instant Wi-Fi integration using ESPHome.
A simple Python tool helps you add new IR codes, customize commands, or support more brands with minimal effort.
Setup takes minutes: flash the included firmware, wire up the IR LED, and connect to your home network.
VintagePioneerIR is flexible—extend functions and make it fit your exact needs.
All code, instructions, and wiring diagrams are available free on GitHub under the MIT License.
Try it and share your experience to help fellow audio enthusiasts modernize classic gear.
Join the discussion and help improve the project in the ESPHome Community!
GitHub:
Githubcode
Let’s keep vintage audio equipment relevant and easier to use in today’s smart homes.
Questions and feedback welcome!
