Virtual switch for disabling binary sensor in esphome
I have water leak sensor and electric control valve.
It works, in HA it looks like on attached picture. ESP8266 automatically close valve if water leak detected, and notify HA.
water
I want to add new feature. I want to have ability to disable water leak sensor for manual only operation.
I think it must be additional switch like “Enable/Disable water leak sensor” but I have not idea how to implement it in esphome. It also must work without connection to HA.
I have only one idea.
New switch will set value for global variable. And inside binary sensor I will analyze value of that global variable. If value represents sensor off value I have to skip scrip execution in binary_sensor.
Maybe there is better way?
My current esphome configuration below:
switch:
  - platform: gpio
    pin: GPIO2 #led pin
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on: #low level, no water
      then:
        - script.stop: water_close
        - script.execute: water_open
    on_turn_off:
      then:
        - script.stop: water_open
        - script.execute: water_close
#M1 for hot water
  - platform: gpio
    pin: D3
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D5
#M2 for cold water
  - platform: gpio
    pin: D6
  - platform: gpio
    pin: D7
  - platform: gpio
    pin: D8
output:
  - platform: esp8266_pwm
    pin: D0
    frequency: 1000 Hz
    min_power: 0.5
    max_power: 0.5
# WATER_DET
binary_sensor:
  - platform: gpio
    pin: D1
    name: "Bathroom water leak"
    device_class: moisture
    on_press: #low level, no water
      then:
    on_release:
      then:
script:
  - id: water_open
    then:
      - switch.turn_on: M1_IN1
      - switch.turn_off: M1_IN2
      - switch.turn_on: M1_ENA
      - delay: 1s # to avoid inrush current
      - switch.turn_on: M2_IN1
      - switch.turn_off: M2_IN2
      - switch.turn_on: M2_ENA
      - delay: 10s
      - switch.turn_off: M1_ENA
      - delay: 1s
      - switch.turn_off: M2_ENA
      - lambda: |-
          id(WaterBathroomVirtualGPIO).publish_state(true);
  - id: water_close
    then:
      - switch.turn_off: M1_IN1
      - switch.turn_on: M1_IN2
      - delay: 1s
      - switch.turn_off: M2_IN1
      - switch.turn_on: M2_IN2
      - delay: 10s
      - delay: 1s
      - lambda: |-
          id(WaterBathroomVirtualGPIO).publish_state(false);
This may be helpful to you: Template Switch — ESPHome
The template switch will be visible to HA and you can use its value to enable/ disable the functionality in esphome itself.
Thank you for solution. Now it looks like this in HA enable
It changes global variable IntSensorEnabled
switch:
    name: "Enable water sensor"
    turn_on_action:
      - lambda: |-
          id(IntSensorEnabled) = 1;
    turn_off_action:
      - lambda: |-
          id(IntSensorEnabled) = 0;
But now I have no idea how to use this variable inside binary sensor
# WATER_DET
binary_sensor:
  - platform: gpio
    pin: D1
      then:
    on_release:
      then:
If IntSensorEnabled == 1 binary_sensor must be executed as is, but if
IntSensorEnabled == 0 binary_sensor must skip running any scripts
Watching this one - I’m interested in how you get to the bottom of this. I’m attempting to disable a PIR sensor on_double_click: to turn on a relay and bypass the PIR sensor on <> off.
Exactly that, AFAIK, binary_sensor doesn’t have a disable feature, only on or off.
Create a dummy switch.
switch:
    optimistic: true
binary_sensor:
  - platform: gpio
    pin: D1
    on_press:
      then:
        - if:
            condition:
              - switch.is_on: script_control
            then:
Thanks a lot! Coolie1101, your solution looks the best and it works as I want!
My current script below:
switch:
  - platform: gpio
    pin: GPIO2 #led pin
      then:
    on_turn_off:
      then:
    optimistic: true
#M1 for hot water
  - platform: gpio
    pin: D3
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D5
#M2 for cold water
  - platform: gpio
    pin: D6
  - platform: gpio
    pin: D7
  - platform: gpio
    pin: D8
output:
    pin: D0
    frequency: 1000 Hz
    min_power: 0.5
    max_power: 0.5
# WATER_DET
binary_sensor:
  - platform: gpio
    pin: D1
      then:
        - if:
            condition:
              switch.is_on: WaterBathroomSensorEnabled
            then:
              - logger.log: "close water"
            else:
              - logger.log: "skip close water"
    on_release:
      then:
        - if:
            condition:
            then:
              - logger.log: "open water"
            else:
              - logger.log: "skip open water"
script:
  - id: water_open
    then:
      - delay: 10s
      - delay: 1s
      - lambda: |-
  - id: water_close
    then:
      - delay: 1s
      - delay: 10s
      - delay: 1s
      - lambda: |-
Hey, I have a related question/problem but for a light.binary
I would like to have a template switch that, if turned off, disables the light component, i.e. one (and also HA) cannot switch the light on/off.
However, on_press doesn’t work within light.binary - only on_turn_on / on_turn_off / on_state are available.
Anyone got an idea how to implement this?
