Visual editor for automations - how to get options in the 'state' dropdown for custom sensors?
I have created a sensor which derives its value from a template, to give a simple indication of whether we are currently away from home and are returning today.
I am also using the visual editor to create automations, which check this value to do things like put the heating on early. However my automations keep going wrong. When I look in the traces I think this is because I am getting the capitalisation wrong of ‘on’ and ‘off’, in different places.
I’ve seen that this problem is avoided when you use a binary sensor, as the visual editor knows what values are allowed (On, Off, Unknown, Unavailable).
Is there a way to define a binary sensor in YAML which gets its state from templating, similar to what I have already done? Or is there a way to define a set of valid values for a sensor which will show up in the dropdown of the visual editor?
    sensors:
      presence_returning_today:
        friendly_name: Presence - returning today
        icon_template: mdi:calendar-today
        value_template: >-
          {% if states.input_datetime.return_date.state == states.sensor.date.state %}
            {{ 'on' }}
          {% else %}
            {{ 'off' }}
          {% endif %}
  1. Define a Template Binary Sensor.
  2. Consider using modern format, instead of legacy format, for all new Template entities you create.
Thanks for those pointers. I’ve been reading around the modern format for templating; although the web seems to be full of older examples rather than the modern ones, I think I have understood it.
However, when I try to define a binary sensor within my configuration.yaml I am getting an error message on the very first line of the new bit of code. I suspect I am making a really simple error - please can you help me work this out?
template:
  binary_sensor:
    - unique_id: test_binary_sensor
      name: Test Binary Sensor
      value_template: >-
          {{ 'on' }}
        {% else %}
          {{ 'off' }}
        {% endif %}
This code is towards the end of my configuration.yaml, with various other declarations of sensor: binary-sensor:, etc before it. Does this matter?
The first two points are syntax errors and the last two are best practices.
  1. Leading hyphen missing from binary_sensor key word.
  2. Modern format uses state key word, not value_template.
  3. For a Template Binary Sensor, its template merely needs to report true/false and it will be interpreted as on/off.
  4. It’s preferable to get an entity’s state value using the states() function as opposed to referencing the entity’s state property directly.
template:
  - binary_sensor:
        state: "{{ states('input_datetime.return_date') == states('sensor.date') }}"
References:
That’s working perfectly. Thanks for taking the time to give such a detailed answer, particularly the advice about best practice :slight_smile:
