VLC player Add as Media Player
Please, make it posible to use VLC player.
It has a webservices in it, you can use for example port :8080
It can play everything. Songs, youtube playlist, streams, live tv channels.
Thanks!
Here is a start:
It is now officially supported in HA but I have no idea on how to make use of it.
This is what I have in my config…
media_player:
  - platform: vlc
After I add it, I can see it created a new entity called media_player.vlc in Dev tools > States.
Now, how do I make use of it? How to verify that it is working?
You can call a service to use it: https://home-assistant.io/components/media_player/
To test it, go to your_ip:8123/dev-service
How does one use this platform? Which VLC interface does it use? Can’t get it to do anything. I’m on Ubuntu.
edit: nevermind, it was this.
Wonder if this is a correct topic. But is there anyway to set - up buffering for vlc?
Might be possible with a command line argument ?
Hey @Danielhiversen, is there any way to play a YouTube video using VLC media player inside Home Assistant?
I get
Oct 10 14:46:05 eXpeditious hass[8628]: [b325e070] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
when my instance starts with this configuration
media_player:
  - platform: vlc
what am I doing wrong? VLC works via the command line and in the X
