VM (Virtualbox) getting errors upon installation
My old NUC died so I got a new one and completely followed the guidelines for creating a Virtualbox VM. However, I get this error during the installation (on ha:8123)
[supervisor.host.sound] Updating PulseAudio information
2025-11-19 15:51:18.899 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-11-19 16:06:18.848 ERROR (MainThread) [supervisor.jobs] Unhandled exception:
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 355, in _wait
    await waiter
asyncio.exceptions.CancelledError
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 299, in wrapper
    return await method(obj, *args, **kwargs)
  File "/usr/src/supervisor/supervisor/docker/interface.py", line 423, in install
    docker_image = await self.sys_docker.pull_image(
    ...<4 lines>...
  File "/usr/src/supervisor/supervisor/docker/manager.py", line 440, in pull_image
    async for e in self.images.pull(
    ...<7 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiodocker/images.py", line 145, in _handle_stream
    async for item in json_stream_stream(response):
        yield item
  File "/usr/local/lib/python3.13/site-packages/aiodocker/jsonstream.py", line 25, in __anext__
    data = yield from self._response.content.readline()
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 360, in readline
    return await self.readuntil()
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 394, in readuntil
    await self._wait("readuntil")
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 354, in _wait
    with self._timer:
  File "/usr/local/lib/python3.13/site-packages/aiohttp/helpers.py", line 713, in __exit__
    raise asyncio.TimeoutError from exc_val
TimeoutError
2025-11-19 16:06:18.878 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-19 16:06:18.878 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-19 16:06:48.883 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2025.11.2
2025-11-19 16:06:48.884 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2025.11.2.
And this just seems to keep repeating. Can anyone help me?
same error while updating from 10.4 to 11.2 seems there is an error @ HA Server not local
UPDATE: I walk away from the laptop and after a while I noticed that the configuration completed. I am now able to setup my home assistant. Unfortunately I don’t know how to check logs to confirm whether the issue got resolved or not.
Hi, I am facing similar issue. I am new to HA and don’t know how to move forward. Did you manage to solve it?
Thank you!
2025-11-25 07:19:51.374 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-11-25 07:34:51.868 ERROR (MainThread) [supervisor.jobs] Unhandled exception:
    await waiter
  File "/usr/src/supervisor/supervisor/docker/interface.py", line 425, in install
    ...<4 lines>...
    ...<7 lines>...
        yield item
    with self._timer:
TimeoutError
2025-11-25 07:34:51.892 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-25 07:34:51.892 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-25 07:35:21.894 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2025.11.3
2025-11-25 07:35:21.895 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2025.11.3.
