I am experimenting with running HAOS on Apple Silicon using VMware Fusion. I have it up and running, but when I try to close/suspend the VM I get this error:
The request to Suspend this virtual machine failed because the corresponding VMware Tools script did not run successfully.
If you have configured a custom suspend script in this virtual machine, make sure that it contains no errors. Attempting the operation again will ignore the script failure. You can also submit a support request to report this issue.
Has anyone encountered this? And/or do you know how to fix it?
