hello
I have a NUC minipc IPC45, (128g ssd, 8g ram) with ubuntu 20.04 lts, I installed VMware player 17 and created a VM (ubuntu 64bits) home assistant with HAOS 11.4 (ova).
when starting it it blocks at the end telling me: “cannot connect to the docker daemon at unix://var/run/docker.sock”.
and I don’t understand why, I followed a lot of tutorials on this problem and even tried the docker from the terminal and it looks ok!!!
Previously I managed to install the same configuration and without problems with the same hardware and software except that the HAOS was in 7.1, (I also tried it is identical.
I think it’s a configuration of Ubuntu or my Vm
Do you have an idea
THANKS
